Your basket is empty
LG Electronics 29" Black Full HD LED Monitor 2560 x 1080 2x 5W Speaker Dis
Quicklinx: C41QWS00 Mfr#: 29UB67-B
Diagonal Size: 29in
Max Resolution: 2560 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI
1 in stock
£243.77 ex VAT
£292.52 inc VAT
Standard delivery Delivered within 3-5 working days
Efficiently run several programs and have multiple active windows on the screen at the same time.
For business meetings, the Dual link-up feature allows two portable devices, such as a computer, camera, phone or Blu-ray player to be connected to the monitor and used on a single screen simultaneously.
LG's smart energy saving mode reduces power consumption without lowering the brightness of the monitor.
LG 29UB67-B - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class C
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
43 W
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
2560 x 1080 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare, 3H Hard Coating
Matte black
70.3 cm x 25.23 cm x 40.4 cm
8.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, cUL, EN 61000-3-3, EN55024, DDC/CI, Directive 2006/95/EC, EN 61000-3-2:2006, TCO Displays 6.0, EN 60950-1:2006, EPA 6.0, EMC 2004/108/EC, EN55022:2006 Class B, DIN ISO 9241-307
Display Type
Energy Class
Class C
62 kWh
43 W
Diagonal Size
29"
Panel Type
AH-IPS
Aspect Ratio
Widescreen - 21:9
Native Resolution
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Power off timer, Multiscan Support, 99% sRGB colour gamut, 4-screen split, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, Smart Energy Saving technology, Color Calibrated, Dual Controller
Matte black
70.3 cm x 25.23 cm x 40.4 cm - with stand
8.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
7 Watt
2 x HDMI , DVI-D (HDCP) , DisplayPort , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
200 x 100 mm
1 x audio cable , 1 x HDMI cable
Backlight Life
50,000 hours
Power Supply
Internal
46 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 70.3 cm - depth: 25.23 cm - height: 40.4 cm - weight: 8.6 kg , Without stand - width: 70.3 cm - depth: 6.2 cm - height: 32.12 cm - weight: 6.3 kg
C41Q C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.75
C41Q C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £21.89
C41Q C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £10.09
C41Q C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £18.04
C41Q C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.01
C41Q C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £12.29
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: C41Q 035695
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £183.41
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Diagonal Size: 29in
Response Time: 5ms
Interfaces: HDMI
Brand: LG Electronics
Stock Status: Used Stock
Price Range Ex VAT: 150 - 300
