IPS Display
The LG IPS Monitor ensures an awesome picture quality that provides clear images and vivid colours from any angle. colour Calibration tests were conducted before the monitors are handed over to consumers. LG's IPS Monitor provides accurate colour for your viewing pleasure.
Motion Energy Saver
The screen turn off /on automatically when the sensor detects you seat or leave in front of monitor.
Ergonomic Design
Pivot & Height, Swivel and Tilt Adjustments support various work environment and office app template.
Reader Mode
Reader Mode provides optimal reading conditions by reducing harmful blue light from LED backlight. You can comfortably read from the monitor - for as long as you want.
Flicker Safe
Reducing the flicker level to almost zero, Flicker-Safe helps you protect your eyes from exhausting flickers. Work and entertain as long as you want!
Smart Energy Saving
LG Smart Energy Saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight, has improved. * Conserve energy by adjusting screen brightness.
- LG 27MB67PY-B - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA, DisplayPort
- Speakers
- Internal
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.4 cm x 25.9 cm x 41 cm
- 6.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, TUV GS, NEMKO, SEMKO, EN 61000-3-3, EN55024, TUV Ergo, DDC/CI, RoHS, Directive 2004/108/EC, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EPA 6.0, EN55022:2006 Class B, DIN ISO 9241-307
- Display Type
- Diagonal Size
- 27"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 135 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, gamma correction, white balance
- sRGB colour management, 4:3 in Wide, SUPER Energy Saving Technology, Multiscan Support, Flicker Safe, Reader Mode, SIX Axis Control, Mercury free, Factory Calibration
- Black
- 64.4 cm x 25.9 cm x 41 cm - with stand
- 6.5 kg
Audio
- Speakers - stereo - internal
- Output Power / Channel
- 1 Watt
- VGA , DVI-D (HDCP) , DisplayPort , 2 x USB 2.0 , Audio line-in
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 355
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 200 x 100 mm
- Cables Included
- 1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable
- Input Voltage
- Power Consumption (Typical)
- 32 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 64.4 cm - depth: 25.9 cm - height: 41 cm - weight: 6.5 kg , Without stand - width: 64.4 cm - depth: 6.4 cm - height: 38.7 cm - weight: 5.1 kg
Sustainability Information
- ENERGY STAR Certified
