Your basket is empty
LG Electronics 27MB67PY-B 27" 1680x1050 VGA DVI IPS Monitor
Quicklinx: C0N2WS00 Mfr#: 27MB67PY-B
IPS Display
The LG IPS Monitor ensures an awesome picture quality that provides clear images and vivid colours from any angle. colour Calibration tests were conducted before the monitors are handed over to consumers. LG's IPS Monitor provides accurate colour for your viewing pleasure.
Motion Energy Saver
The screen turn off /on automatically when the sensor detects you seat or leave in front of monitor.
Ergonomic Design
Pivot & Height, Swivel and Tilt Adjustments support various work environment and office app template.
Reader Mode
Reader Mode provides optimal reading conditions by reducing harmful blue light from LED backlight. You can comfortably read from the monitor - for as long as you want.
Flicker Safe
Reducing the flicker level to almost zero, Flicker-Safe helps you protect your eyes from exhausting flickers. Work and entertain as long as you want!
Smart Energy Saving
LG Smart Energy Saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight, has improved. * Conserve energy by adjusting screen brightness.
LG 27MB67PY-B - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Speakers
Internal
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
64.4 cm x 25.9 cm x 41 cm
6.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, TUV GS, NEMKO, SEMKO, EN 61000-3-3, EN55024, TUV Ergo, DDC/CI, RoHS, Directive 2004/108/EC, Directive 2006/95/EC, EN 61000-3-2:2006, TCO Displays 6.0, EN 60950-1:2006, EPA 6.0, EN55022:2006 Class B, DIN ISO 9241-307
Display Type
Diagonal Size
27"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
135 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, gamma correction, white balance
sRGB colour management, 4:3 in Wide, SUPER Energy Saving Technology, Multiscan Support, Flicker Safe, Reader Mode, SIX Axis Control, Mercury free, Factory Calibration
64.4 cm x 25.9 cm x 41 cm - with stand
6.5 kg
Audio
Speakers - stereo - internal
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , DisplayPort , 2 x USB 2.0 , Audio line-in
Mechanical
Tilt Angle
-5/+35
Swivel Angle
355
Height Adjustment
130 mm
Flat Panel Mount Interface
200 x 100 mm
1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable
32 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 64.4 cm - depth: 25.9 cm - height: 41 cm - weight: 6.5 kg , Without stand - width: 64.4 cm - depth: 6.4 cm - height: 38.7 cm - weight: 5.1 kg
ENERGY STAR Certified
C0N2 C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.38
C0N2 C2G HDMI to DisplayPort Adapter Converter In Stock £33.32
C0N2 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £20.49
C0N2 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
C0N2 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £15.00
C0N2 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £11.49
