Energy Saving
Enjoy the bright screen without any image loss. Save additional energy compared to conventional LED monitors. * Conserve energy by adjusting screen brightness.
Reader Mode
By reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for longer periods of time without straining your eyes.
Flicker Safe
Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction.
Ergonomic Design
Our swivel tilting monitor has diverse swivel & tilt options ranged from 15° to 68° and from -5° to 35° respectively, to be perfectly adjusted for varied eye level and working conditions. Also, our pivot monitor can be changed to vertical anytime you want, keeping up with business situations like dealing with vertically long contents.
Built-in Power
Experience built-in adaptor which used to be assembled in the power cable. Feel how our built-in adaptor remarkably changed installation time to be a more convenient by omitting any struggles to pull it out from small size cable hole.
- LG 24MB35PH - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Energy Consumption per Year
- 37 kWh
- Power Consumption (On mode)
- 25 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.9 cm x 27.1 cm x 43.2 cm
- 5.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, CSA, UL, TUV GS, EN 61000-3-3, EN55024, TUV Ergo, DDC/CI, EN 61000-3-2:2006, EN 60950-1:2006, EN55022:2006 Class B
- 2-year warranty
- Display Type
- Energy Class
- Class F
- 37 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, gamma correction, phase, clock
- 4:3 in Wide, SUPER Energy Saving Technology, Dual Smart Solution
- Black
- 56.9 cm x 27.1 cm x 43.2 cm - with stand
- 5.1 kg
- VGA , DVI-D (HDCP) , HDMI , Audio line-out
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 355
- Rotation Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Power Supply
- Internal
- Input Voltage
- 25 W
- Power Consumption SDR (On mode)
- 20 kWh/1000h
- Power Consumption (Typical)
- 31 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 56.9 cm - depth: 27.1 cm - height: 43.2 cm - weight: 5.1 kg , Without stand - width: 56.9 cm - depth: 6.3 cm - height: 34.2 cm - weight: 4.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - pick-up and return
