LG Electronics 22MP67VQ 22" 1920x1080 5ms VGA DVI-D HDMI IPS LED Monitor
Quicklinx: B6SVWS00 Mfr#: 22MP67VQ
With an LG computer monitor you'll discover cutting-edge display technology and slim designs, from the LG CINEMA 3D monitor, the standard in 3-dimensional excellence, to the dazzling LED and LCD monitors, which offer state-of-the-art display and features. You'll get a outlook on life with monitors and other computer equipment from LG.
  • IPS display
    The LG IPS Monitor ensures an awesome picture quality that provides clear images and vivid colors from any angle. Color Calibration tests were conducted before the monitors are handed over to consumers. LG's IPS Monitor provides accurate color for your viewing pleasure.
  • Cinema Screen design
    The Cinema Screen design offers an immersive experience both in terms of form and content. Thanks to its elegant design, it also delivers an aesthetic value of its own.
  • 4-Screen Split
    The 4-Screen Split feature improves productivity by simply re-sizing the windows on your screen. With one drag you can re-size one window and the other windows automatically to fir the available space. It allows from 2 to 4 windows to be shown in 8 different screen ratios without feeling cluttered.
  • Color Cloning
    It's easy to build up a multi-tasking environment with multiple monitors. Color Cloning APP helps you to match the color quality and brightness between two LG monitors that are connected to the same PC.
  • Color Wizard
    The Color Wizard feature prevents color-weak people from missing important content by distinguishing certain ranges of colors via the color revision algorithm.
  • Flicker Safe
    Reducing the flicker level to almost zero, Flicker-Safe helps you protect your eyes from exhausting flickers. Work and entertain as long as you want with the IPS monitor.
  • Reader Mode
    Reader Mode provides optimal reading conditions by reducing harmful blue light from LED backlight. You can comfortably read from the monitor - for as long as you want.
LG 22MP67VQ - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
50 cm x 20.5 cm x 40.7 cm
3 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, Directive 2004/108/EC, Directive 2006/95/EC, EN 61000-3-3:2008, Directive 2009/125/EC, EN 61000-3-2:2006+A1:2009+A2:2009, EPA 6.0, EN 50564:2011, EN 50581:2012, RoHS 2011/65/EU, EN 50563:2011, EN 55024:2010, EN 55022:2010, IEC 62087:2008, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
Display Type
Energy Class
Class B
35 kWh
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP, SUPER + Resolution, CINEMA Screen Design, 4-screen split, Flicker Safe, Reader Mode, Joystick, Color Cloning, Smart Energy Saving technology, Color Wizard, Colour Calibration
50 cm x 20.5 cm x 40.7 cm - with stand
3 kg
HDMI , Headphones , VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-3/+20
VESA Mounting Interface
75 x 75 mm
1 x VGA cable
Power Supply
External
24 W
Power Consumption (Typical)
21 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Windows 8
Dimensions & Weight Details
With stand - width: 50 cm - depth: 20.5 cm - height: 40.7 cm - weight: 3 kg , Without stand - width: 50 cm - depth: 5.2 cm - height: 30.6 cm - weight: 2.6 kg
