The screen turn off/on automatically when the sensor detects you seat or leave in front of monitor.
Pivot & Height, Swivel and Tilt Adjustments support various work enviornment and office app template.
Reader Mode provides optimal reading conditions by reducing harmful blue light from LED backlight. You can comfortablly read from the monitor - for as long as you want.
- LG 22MB67PY - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- USB Hub
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050
- Brightness
- 250 cd/m²
- Contrast Ratio
- 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- 50.6 cm x 23.9 cm x 36.5 cm
- 4.7 kg
- Plug and Play, FCC Class B certified, UL, TUV GS, cUL, ISO 13406-2, TUV Ergo, DDC/CI, EPA
- Display Type
- Diagonal Size
- 22"
- Built-in Devices
- USB Hub
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- OSD Languages
- Hindi, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
- HDCP, Flicker Safe, Reader Mode, SIX Axis Control, Smart Energy Saving technology, Intelligent Auto, Motion Energy Saver
- 50.6 cm x 23.9 cm x 36.5 cm - with stand
- 4.7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , DisplayPort , USB upstream , 2 x USB downstream , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Rotation Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- Cables Included
- 1 x audio cable , 1 x USB cable
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 33 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Windows 8
- Dimensions & Weight Details
- With stand - width: 50.6 cm - depth: 23.9 cm - height: 36.5 cm - weight: 4.7 kg , Without stand - width: 50.6 cm - depth: 5.8 cm - height: 33.9 cm - weight: 3.5 kg
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
