Display
LG LED Monitor features HD resolution(1680*1050), resulting in 250nit of its brightness which brings a crystal-clear image. Fast response time of 5ms helps you to avoid motion blur and let you enjoy the fastest action movies as well.
Stereo Speakers
Built in stereo speaker enables you to take a sound test without extra speakers.
Energy Saving
Enjoy the bright screen without any image loss. Save additional energy compared to conventional LED monitors. * Conserve energy by adjusting screen brightness.
Reader Mode
Reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for long.
Flicker Safe
Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction.
Ergonomic Design
Our swivel tilting monitor has diverse swivel & tilt options ranged from 15° to 68° and from -5° to 20° respectively, to be perfectly adjusted for varied eye level and working conditions. Also, our pivot monitor can be changed to vertical anytime you want, keeping up with business situations like dealing with vertically long contents.
Built-in Power
Experience built-in adaptor which used to be assembled in the power cable. Feel how our built-in adaptor remarkably changed installation time to be a more convenient by omitting any struggles to pull it out from small size cable hole.
- LG 22MB65PM-B - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050 at 60 Hz
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Anthracite dark
- Dimensions (WxDxH) - without stand
- 50.6 cm x 5.8 cm x 33.9 cm
- 3.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, CSA, UL, TUV GS, C-Tick, NEMKO, SEMKO, VCCI-II, EN 61000-3-3, EN55024, EN55022 Class B, TUV Ergo, ISO 9241-307, EN 61000-3-2:2006, EN 60950-1:2006
- 3-year warranty
- Display Type
- Diagonal Size
- 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 135 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Contrast, H/V position, gamma correction, phase, clock
- Power off timer, Digital Fine Contrast (DFC), 4:3 in Wide, SUPER Energy Saving Technology, Multiscan Support
- Anthracite dark
- 50.6 cm x 5.8 cm x 33.9 cm - without stand
- 3.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D (HDCP) , Audio line-in , Audio line-out
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 355
- Rotation Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Backlight Life
- 50,000 hours
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 50.6 cm - depth: 23.9 cm - height: 37.9 cm - weight: 4.7 kg , Without stand - width: 50.6 cm - depth: 5.8 cm - height: 33.9 cm - weight: 3.5 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - backlight - 3 years
C2G 2m HDMI to DVI-D Digital Video Cable | In Stock | £11.38 |
