Kick back, relax and immerse yourself with a 2.1 Ch surround sound speaker system which brings to life all of your favorite movies, music, soaps and shows.
Play your favorite music from your smartphone or Bluetooth enabled device on your LG soundbar by wirelessly streaming via Bluetooth.
Surround your senses with sound
Kick back, relax and immerse yourself with a 2.1 Ch surround sound speaker system which brings to life all of your favorite movies, music, soaps and shows. -
Update manager
Always keep your sound bar up-to-date with the firmware options that can all be updated from your smart devices wirelessly. -
Wireless audio streaming via Bluetooth
Play your favorite music from your smartphone or Bluetooth enabled device on your LG soundbar by wirelessly streaming via Bluetooth. -
Active wireless subwoofer
Free your living room from wires. LG's active wireless subwoofer allows you to enjoy superb sound quality without compromising on design. -
Mood station
LGs Mood Matrix recommends songs to match your current mood or activity and can automatically create playlists.
- LG LAS550H - sound bar system - wireless
- Product Type
- Sound bar system - 2.1-channel
- Media Content Source
- USB-host
- System Components
- Subwoofer, sound bar
- Enclosure Design
- Bass reflex
- Speaker Type
- Active
- Nominal Output Power (Total)
- 320 Watt
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- WAV, WMA, MP3, FLAC, LPCM, OGG
- Speaker System Details
- 1 x sound bar 120 Watt , 1 x subwoofer 200 Watt
- Speaker Details
- Sound bar - stereo x 2 - 60 Watt - at 1 kHz - 10% THD - 2-way - active , Speaker - subwoofer - at 80 Hz - 10% THD - 3 Ohm - active
- Built-in Decoders
- Dolby Digital, DTS decoder, SBC decoder
- Sound Effects
- Vertical Surround, Sound Sync
- Power Options
- Auto power on/off
- 1-year warranty
- Product Type
- USB-host
- Enclosure Design
- Bass reflex
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 320 Watt
- Amplifier
- Integrated
- Sound Effects
- Audio Return Channel (ARC) Capability
- Bluetooth 4.0
- Built-in Decoders
- Audio Formats
- Controls
- EQ mode selector, volume, treble, bass
- Additional Features
- Bi-amplified, Audio Return Channel (ARC), night mode, SIMPLINK technology
- Speakers Included
- 1 x sound bar - 2-way - 120 Watt - wall-mountable - wireless , 1 x subwoofer - 200 Watt - wireless
- Speaker Details
- Sound bar - stereo x 2 - 60 Watt - at 1 kHz CFR - 10% THD - 2-way - active , Speaker - subwoofer - at 80 Hz CFR - 10% THD - 3 Ohm - active
- Driver Details
- Sound bar: 2 x woofer driver - 1.57 x 3.94" , Sound bar: 2 x tweeter driver - 0.79"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 6"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link) , USB (4 PIN USB Type A) , HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A)
- Included Accessories
- Power adapter, remote control, wall mounting kit
- Power Source
- AC power adapter
- Options
- Auto power on/off
- Dimensions (WxDxH) / Weight Details
- Sound bar: 89 cm x 8.5 cm x 5.1 cm / 2.8 kg , Subwoofer: 17.1 cm x 39 cm x 26.1 cm / 5.6 kg
- Limited warranty - parts and labour - 1 year
