LG 65SE3KD 65" 1920x1080 HDMI Large Format Display - Black
Quicklinx: F19RWS00 Mfr#: 65SE3KD
TV Tuner Presence: No
Video Interface: HDMI
  • 1080p (Full HD)
Hurry, only 2 left in stock!
£1,339.67 ex VAT
£1,607.60 inc VAT
The thinner bezel allows a perfect fit for a sleek look. Portrait mode allows the logo to be positioned in the desired setting. The well-organized cable terminals in the back optimize available space. Play and schedule contents with a USB connection - no server connection required. Circuit board reliability is enhanced with conformal coating that protects against dust, iron powder, humidity and other harsh conditions.
  • Slimmer bezel
  • Detachable logo
  • Cable management
  • USB content scheduling
  • Conformal coating
LG 65SE3KD-B SE3KD - 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi (optional), LAN
PC Interface
DVI, VGA (HD-15)
IPS
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SNMP support, detachable logo, Local Time Auto Setting, Contents Scheduling, SuperSign-c compatible, SuperSign-w compatible
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
95 Watt
145.69 cm x 5.65 cm x 83.8 cm
27.9 kg
Environmental Standards
ENERGY STAR Qualified
95 Watt
Diagonal Class
65"
Commercial Use
Series
SE3KD
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
Modes
Portrait mode, landscape mode
Dimensions
Without stand
145.69 cm
5.65 cm
83.8 cm
27.9 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare, 3H Hard, conformal
Image Contrast Ratio
1300:1
Dynamic Contrast Ratio
500000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
7.6 ms
Commercial Features
Operation Hours / Days
18 / 7
Enhanced Image Sticking Minimization
Stands & Mounts
Stand
Optional
VESA Mounting Interface
300 x 300 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x speaker - built-in - 10 Watt
Network & Internet Multimedia
Connector Type
Serial input , Serial output , Audio line-in , Audio line-out , USB , DVI-D input , VGA input , Infrared input , Network , 2 x HDMI input
2 batteries
VGA cable , Serial adapter
FCC Class A certified, UL, TUV, cUL, CB, EMC, KCC, KC
ENERGY STAR Certified
ENERGY STAR Version
7.0
Power supply
Nominal Voltage
WOL (Wake on LAN)
Dimensions & Weight Details
Panel without stand - 145.69 cm x 5.65 cm x 83.8 cm x 27.9 kg , Panel with stand - 145.69 cm x 29.37 cm x 89.81 cm x 33.1 kg
Width (Shipping)
156.1 cm
Depth (Shipping)
19 cm
Height (Shipping)
97.7 cm
Weight (Shipping)
33.8 kg
10 - 80%
Brand: LG
Price Range Ex VAT: 1000 - 1500
