LG 43UD79-B 43" 3840x2160 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: D8XYWS00 Mfr#: 43UD79
Diagonal Size: 42.51in
Max Resolution: 3840 x 2160
Response Time: 8ms
Interfaces: DisplayPort, HDMI
£547.01 ex VAT
£656.41 inc VAT
The 43UD79-B, this 42.5-inch display has a native UHD resolution of 3840 x 2160 with a conventional refresh rate of 60Hz. It features an IPS panel with a non-glare coating, a peak brightness of 350 cd/m2, a contrast ratio of up to 1000:1, and an 8ms gray-to-gray (GTG) response time. The viewing angles are wide at 178°/178°, which is typical for an IPS display. Although support for 1.07 billion colors is claimed, the lack of an explicit mention of a 10-bit panel leads us to believe that this is an 8-bit panel using A-FRC to achieve a 10-bit color depth. On the plus side, this model will ship color calibrated from the factory.
  • 43" Class 4K UHD IPS display
    Outstanding Ultra HD performance is assured by the specially designed 4K display panel with in-plane switching (IPS), delivering accurate colors that remain consistent at wide viewing angles, with four times the resolution of Full HD.
  • HDCP 2.2 compatible
    Connect with confidence: This LG 4K monitor is compatible with the latest HDCP 2.2 copy protection, so it will display video from 4K streaming services, game consoles and Ultra HD Blu-ray disc players.
  • USB Type-C (DP Alt mode)
    Offering a generation of convenience, USB Type-C (DP Alt mode) ports allow 4K video display and mobile device charging, all at the same time over a single cable.
  • 4x HDMI inputs
    Now, the monitor is a multimedia centerpiece. Easily and conveniently connect your other digital devices and peripherals with the convenience of 4 HDMI inputs.
  • Adjust display settings with remote
    Picture mode presets, including Picture in Picture, can be easily adjusted with the included remote control.
  • Screen split
    Customize your monitor layout for multitasking with the latest version of LG Screen Split. Resize and display multiple windows at once, with 14 options including four different picture-in-picture (PIP) choices.
  • 10 watt speakers with rich bass
    Enjoy what's on the screen with sound produced by the monitor's two 10 watt speakers with rich bass. LG's rich bass function can cover sound under 85Hz showcasing a wider and richer sound with impressive bass depth.
LG 43UD79-B - LED monitor - 4K - 42.51"
LED-backlit LCD monitor - 42.51"
Energy Class
Class A
Energy Consumption per Year
98 kWh
Power Consumption (On mode)
67 W
USB 3.0 hub
Panel Type
IPS
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey)
Colour Support
1.06 billion colours
Input Connectors
4xHDMI, DisplayPort
3-year warranty
Display Type
Energy Class
Class A
98 kWh
67 W
Diagonal Size
42.51"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Mega DFC
4 x HDMI , DisplayPort , USB-C , 2 x USB 3.0 downstream , Serial , Audio line-out
75 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Limited warranty - 3 years
LG 43UD79-B 43 Bundle deal on LG 43UD79-B 43" 3840x2160 5ms HDMI DisplayPort IPS LED Monitor
£646.18
Response Time: 8ms
Interfaces: HDMI
Brand: LG
Price Range Ex VAT: 500 - 750
