LG 43" Hotel Black Commercial TV Full HD VESA
Installation required? Contact us today!
Quicklinx: F1J4WS00 Mfr#: 43LV541H
TV Tuner Presence: Yes
Video Interface: Component, Composite, HDMI
  • 1080p (Full HD)
£359.00 ex VAT
£430.80 inc VAT
Pro: Centric enables to differentiate guest room experiences with customizable billboards and Electronic Program Guide which easily navigates TV channels and program. Optimize TCO with Pro: Centric by saving workforce and time for development & management cost for hospitality solutions. Expand the rage of comfort for the guests with a commercial grade stand by allowing them to watch a TV from any angle. Enhance the entertainment experience by adding an additional speaker. Guests listen to and control the TV audio from anywhere in the business areas, including restrooms. One channel map feature allows users to edit and list the channels of their choice from any of the multiple broadcasting signals. Multi IR function eliminates the remote control signal interference between TVs in multiple dwelling beds.
  • Enhanced guest experience
  • Optimized total cost of ownership
  • Commercial swivel stand
  • External speaker out
  • One channel map
  • Multi IR
LG 43LV541H LV541H Series - 43" LED TV
LED-backlit LCD TV
Diagonal Class
43"
Commercial Use
Yes - hotel / hospitality
Resolution
1920 x 1080
Display Format
1080p (Full HD)
24p Technology
24p Real Cinema
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
LAN
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Analogue TV Tuner
PAL, SECAM
Commercial Features
Screen welcome message, hotel mode, Multi remote control, Remote Diagnosis, Lock Mode, flash support, Pro:Centric V, Self Diagnostics, Pro:Centric HCAP (SDK)
Settings Cloning Capability
Picture Enhancements
Triple XD Engine
Speaker System
2 speakers
USB
Voltage
Energy Class
Class A+
88.7 Watt
Power Consumption (On mode)
53 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
74 kWh
97.4 cm x 7.94 cm x 57.1 cm
LED-backlit LCD TV
Energy Class
Class A+
88.7 Watt
53 W
74 kWh
Diagonal Class
43"
Commercial Use
Series
LV541H Series
TV Tuner Presence
Video Interface
HDMI Ports Qty
3 ports
Triple XD Engine
Dimensions
Without stand
97.4 cm
7.94 cm
57.1 cm
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
24p Technology
24p Real Cinema
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pull-Down Compensation
3:3
Response Time
9 ms
Commercial Features
One Channel Map, security lock slot (cable lock sold separately), EzManager, RJP Compatible, Instant On, Lock Down Plate, Motion eye care
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Features
Swivel
VESA Mounting Interface
200 x 200 mm
TV Tuner
Analogue TV Tuner
PAL, SECAM
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Media Player
USB Port
USB Ports Qty
1
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Clear Voice technology
Speakers
2 x speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
Digital audio output (optical) - rear , Headphones - rear , LAN - rear , 2 x HDMI - side , Speakers output - rear , Serial input - rear , Composite video / component video / audio input - rear , USB - side , HDMI - rear
CB, RoHS, ERP, CU-TR
Power supply
Nominal Voltage
0.3 Watt
Smart energy saving
Dimensions & Weight Details
Panel without stand - 97.4 cm x 7.94 cm x 57.1 cm , Panel with stand - 97.4 cm x 30.3 cm x 62.5 cm x 12.5 kg
Width (Shipping)
114.7 cm
Depth (Shipping)
17.5 cm
Height (Shipping)
66 cm
Weight (Shipping)
14.6 kg
Video Interface: Composite
Video Interface: HDMI
Brand: LG
Price Range Ex VAT: 300 - 500
