LG 38WK95C 38" 3840x1600 5ms HDMI DisplayPort USB-C UltraWide Curved IPS LED Monitor
Quicklinx: DNDXWS00 Mfr#: 38WK95C
Diagonal Size: 37.5in
Max Resolution: 3840 x 1600
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
Hurry, only 2 left in stock!
£968.66 ex VAT
£1,162.39 inc VAT
Walk into The New World of HDR
HDR is now considered the industry standard for high-quality pictures in display devices. HDR 10 supported monitors can display HDR-coded games with the latest consoles and HDR videos from major streaming "Video On Demand" Services.
HDR 10 - Detailed Contrast
HDR-compatible monitors display brighter whites and blacker blacks compared to conventional displays. HDR renders dark and bright areas of an image, enhancing details whcih where more difficult to see under the old standards.
HDR Effect to SDR Content
HDR Effect feature uses a picture quality algorithm to convert non-HDR content into high quality video on par with vivid HDR visuals.
True Colours and Wider View
LG IPS monitors display impeccable colour accuracy. With a wider viewing angle, the IPS display boasts 99% coverage of the sRGB colour spectrum.
More Space for Multi-Tasking
The UltraWide™ QHD+(3840x1600) resolution is equivalent to three times that of a 16:9 Full HD (1920x1080) whilst providing more space than a 34-inch 21:9 QHD real estate, making it ideal for viewing and processing more information.
Immersive Visual Experience
This streamlined display features a slim bezel on three sides and Rich Bass providing an immersive Audio and Visual experience.
Easy Control and Connectivity
With USB Type-C™, which offering reliable compatibility with both Laptops and MacBook. With USB Type-C™, you can connect your display, transfer data and charge your laptop or a mobile device, up to 60W over a single cable.
Versatile Elegance
The curved base enhances stability for dependable performance. The base can be adjusted to change the tilt, height and angle of the monitor for a more comfortable viewing experience.
LG 38WK95C-W - LED monitor - curved - 37.5"
LED-backlit LCD monitor - 37.5"
Energy Class
Class B
Energy Consumption per Year
76 kWh
Power Consumption (On mode)
52 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
UWQHD+ 3840 x 1600 at 75 Hz
Pixel Pitch
0.229 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
1.073 billion colours (8-bit)
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Glossy white back cover, black front, silver frame and base
89.72 cm x 23.04 cm x 46.62 cm
9.3 kg
FCC Class B certified, UL, TUV, EN 61000-3-3, EN55024, DDC/CI, EN 61000-3-2:2006, EN 60950-1:2006, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2006 Class B, EPA 7.0, HDCP 2.2
Display Type
Energy Class
Class B
76 kWh
52 W
Diagonal Size
37.5"
Curved Screen
Yes (2300R)
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.229 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 101 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean, UK English
HDCP, split screen, game mode, Mega Contrast, Multiscan Support, On-screen Digital Controls, 99% sRGB colour gamut, Flicker Safe, Reader Mode, Dual Link-up, Factory Calibration, 6-axis colour adjustment, MaxxAudio, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), FreeSync Technology, My Display Preset, Color Weakness Mode, Mega DFC, USB 3.0 Quick Charge, Bluetooth Audio, Rich Bass, HDR10 compatible
89.72 cm x 23.04 cm x 46.62 cm - with stand
9.3 kg
Audio
Speakers - stereo
Output Power / Channel
10 Watt
2 x HDMI , USB-C , Audio line-out , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Height, tilt
Tilt Angle
-5/+15
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
ArcLine stand
1 x HDMI cable , 1 x DisplayPort cable - 1.8 m , 1 x USB-C cable - 1 m
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 89.72 cm - depth: 23.04 cm - height: 46.62 cm - weight: 9.3 kg , Without stand - width: 89.72 cm - depth: 9.15 cm - height: 39.3 cm - weight: 7.7 kg
Shipping Width
105.3 cm
Shipping Depth
20.7 cm
Shipping Height
53.8 cm
Shipping Weight
13.2 kg
LG 38WK95C 38 Bundle deal on LG 38WK95C 38" 3840x1600 5ms HDMI DisplayPort USB-C UltraWide Curved IPS LED Monitor
£1,068.42
Response Time: 5ms
Interfaces: HDMI
Interfaces: USB-C
Brand: LG
Price Range Ex VAT: 750 - 1000
