The world's first 38-inch curved IPS monitor. The 21:9 curved UltraWide QHD+ IPS Display is ideal for designers, photographers, producers and other creative professionals who need more room for big ideas. With exceptional picture quality and innovative features, this UltraWide monitor is for seriously professional creative talents.
The Wide Quad High Definition+ (WQHD+) resolution is four times clearer than basic HD, for stunning picture quality. Designed for display of advanced graphics on a wide screen, WQHD+ delivers an amazing 3840 x 1600 pixels.
With FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync nearly eliminates tearing and stuttering that can occur because of differences between a graphic card's frame rate and a monitor's refresh rate.
38 inch UltraWide curved display
The world's first 38-inch curved IPS monitor. The 21:9 curved UltraWide QHD+ IPS Display is ideal for designers, photographers, producers and other creative professionals who need more room for big ideas. With exceptional picture quality and innovative features, this UltraWide monitor is for seriously professional creative talents. -
QHD+ screen resolution
The Wide Quad High Definition+ (WQHD+) resolution is four times clearer than basic HD, for stunning picture quality. Designed for display of advanced graphics on a wide screen, WQHD+ delivers an amazing 3840 x 1600 pixels. -
FreeSync
With FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync nearly eliminates tearing and stuttering that can occur because of differences between a graphic card's frame rate and a monitor's refresh rate. -
1ms Motion Blur Reduction
A monitor's response time is absolutely critical in games. The 1ms Motion Blur Reduction feature will allow gamers to enjoy the precision and accuracy needed to play at a very high level. With a response time that is virtually 1ms, blurring and ghosting are dramatically reduced to make the in-game action smoother and gamer reactions more -
USB Type-C & USB 3.0 quick charge
Display 4K video, transfer data and charge a laptop or mobile device, all at the same time using a single cable with USB Type-C. Charge the battery of a connected device quickly using the USB 3.0 port. This port charges compatible devices much faster than typical USB 2.0 cables so waiting for a full charge doesn't hold you up. -
Bluetooth audio with rich bass
With a Bluetooth connection, enjoy the music from a mobile device right through the monitor's built-in speaker (10 W x2). The monitor's speaker delivers powerful and vivid sound quality enhanced by LG's Rich Bass function that covers sound under 85 Hz for richer sound with impressive bass depth. -
sRGB Over 99%
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
- LG 38UC99-W - LED monitor - curved - 38"
- LED-backlit LCD monitor - 38"
- Energy Class
- Class B
- Energy Consumption per Year
- 72 kWh
- Power Consumption (On mode)
- 50 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 24:10
- Native Resolution
- 3840 x 1600 (DisplayPort: 60 Hz, HDMI: 30 Hz)
- Pixel Pitch
- 0.2299 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- 2xHDMI, DisplayPort
- Height, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black front panel, white (back), silver/white stand
- 89.72 cm x 23.04 cm x 46.62 cm
- 9.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, UL, TUV, EN 61000-3-3, EN55024, DDC/CI, RoHS, Directive 2004/108/EC, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EPA 6.0, EN55022:2006 Class B, CE/EMC
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 72 kWh
- Diagonal Size
- 38"
- Viewable Size
- 37.5"
- Curved Screen
- Yes (2300R)
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- AH-IPS
- Aspect Ratio
- 24:10
- Native Resolution
- Pixel Pitch
- 0.2299 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 56 - 61 Hz
- Horizontal Refresh Rate
- 30 - 101 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Picture in picture, game mode, Mega Dynamic Contrast Ratio, Multiscan Support, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, Mercury free, Motion Blur Reduction, Factory Calibration, MaxxAudio, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), My Display Preset, USB 3.0 Quick Charge, Bluetooth Audio, 99% sRGB colour gamut
- 89.72 cm x 23.04 cm x 46.62 cm - with stand
- 9.3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 10 Watt
- 2 x HDMI , DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , Audio line-out , USB-C
Mechanical
- Height, tilt
- Tilt Angle
- -5/+15
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Cable holder
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C cable - 1 m , 1 x USB cable
- Input Voltage
- 50 W
- Power Consumption (Typical)
- 57 Watt
- Power Consumption Stand by
- 1.2 Watt
- 0.3 Watt
- Included Software
- Screen Split Software, Dual Controller Software
- OS Required
- Apple MacOS X
- Dimensions & Weight Details
- With stand - width: 89.72 cm - depth: 23.04 cm - height: 46.62 cm - weight: 9.3 kg , Without stand - width: 89.72 cm - depth: 9.15 cm - height: 39.3 cm - weight: 7.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - carry-in
