The pinnacle of gaming monitors. Complete your battle station with a premium LG UltraGear gaming monitor. Built for gamers, it delivers the latest hardware, specs, ergonomics, sleek design and sensory experience. With gaming-focused features like NVIDIA G-SYNC compatibility, 1ms GTG response times, pro-level customization and a fast, vivid IPS panel, you're sure to gain an added edge.
                Total game changer with Nano IPSLG UltraGear gaming monitors are created from the ground up to give gamers the edge, including verified NVIDIA G-SYNC compatibility. The Nano IPS display achieves 1ms GTG TN-level speeds and ultra-fast refresh rates, while mesmerizing with a rich and vivid picture.
                Picture perfection with 1ms response ratesThe Nano IPS panel creates a vivid, rich virtual world, yet cuts response rates to 1 ms. Whatever genre you're into, enjoy picture quality as intense as the game itself in high resolution. It presents realism and true color at wide viewing angles, while HDR brings new worlds to life.
                HDR 600: ultimate picture quality like never beforeSee a gaming world that's virtually perfect. VESA DisplayHDR 600 brings that world to life with an experience that surpasses reality. This next-level display tech elevates textures, surrounding elements, realistic character movements and natural recreations of sun and shadow.
                Overclock 160 Hz: total immersion with overwhelming speedOverclock boosts refresh rates from 144 Hz to an ultra-fast 160 Hz, displaying less motion blur and smooth movement. Gamers see fast action, obstacles and opponents in near real time for a clear advantage.
                Gain an edge with NVIDIA G-SYNC compatibilityOfficially verified NVIDIA G-SYNC compatibility. That translates to faster, smoother gaming that's been tested to reduce screen tearing, while minimizing stutter and input lag. Never miss a frame of the action as you clinch your victories with lag-free refresh rates.
                Stylish design to light up the sensesLG UltraGear gaming monitors are created to frame up virtual worlds in a clean, sleek, minimal design. Yet they're crafted to maximize your experience with pro-level control, gaming modes and adjustable ergonomics. RGB sphere lighting even lights up in sync with the gaming action bright enough to create an ambient effect around your battle station.
- LG UltraGear 38GN950-B - LED monitor - curved - 37.5" - HDR
- LED-backlit LCD monitor - 37.5"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/356500
- Energy Class
- Class G
- Power Consumption (On mode)
- 41.9 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync Premium Pro, NVIDIA G-SYNC Compatible
- USB 3.0 hub
- Panel Type
- Nano IPS
- Aspect Ratio
- 21:9
- Native Resolution
- UWQHD+ 3840 x 1600 at 144 Hz
- Pixel Pitch
- 0.2291 mm
- Brightness
- 450 cd/m²
- Contrast Ratio
- 1000:1
- HDR Capable
- HDR10 / DisplayHDR 600
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 98% DCI-P3 (CIE 1976)
- Input Connectors
- 2xHDMI, DisplayPort
- Height, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- 89.64 cm x 31.22 cm x 47.84 cm
- 9.2 kg
- DisplayPort 1.4
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Diagonal Size
- 37.5"
- Curved Screen
- Built-in Devices
- USB 3.0 hub
- Panel Type
- Nano IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.2291 mm
- Brightness
- 450 cd/m²
- Contrast Ratio
- 1000:1
- HDR Format
- HDR10
- HDR Certification
- DisplayHDR 600
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- On-screen Digital Controls, Black Stretch technology, Crosshair Display, Flicker Safe, Reader Mode, Wide Colour Gamut, Color Calibrated, DAS Mode (Dynamic Action Sync), Sphere Lighting 2.0, Sound Sync mode, Video Sync mode, overclocked 160 Hz
- 89.64 cm x 31.22 cm x 47.84 cm - with stand
- 9.2 kg
- 2 x HDMI , DisplayPort , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream , Headphones
Mechanical
- Height, tilt
- VESA Mounting Interface
- 100 x 100 mm
- Maxx Audio support
- DisplayPort 1.4
- Input Voltage
- 41.9 W
- Power Consumption SDR (On mode)
- 41.9 kWh/1000h
- Power Consumption HDR (On mode)
- 106 kWh/1000h
- Power Consumption (Typical)
- 70 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Included Software
- LG UltraGear Control Center
- Dimensions & Weight Details
- With stand (lowest position) - width: 89.64 cm - depth: 31.22 cm - height: 47.84 cm - weight: 9.2 kg , With stand (highest position) - width: 89.64 cm - depth: 31.22 cm - height: 58.84 cm - weight: 9.2 kg , Without stand - width: 89.64 cm - depth: 11.13 cm - height: 39.44 cm - weight: 7 kg
