LG 34WK650 34" 2560x1080 5ms HDMI DisplayPort UltraWide IPS LED Monitor
Quicklinx: DNDSWS00 Mfr#: 34WK650
HDR 10
To more fully realize content creators’ vision, this monitor is compatible with industry-standard HDR10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
HDR Effect
The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm.
IPS with sRGB 99% (Typ.)
This monitor, with 99% coverage of the sRGB spectrum, is a great solution for photographers, graphic designers or anyone looking for highly accurate color.
Virtually Borderless Design
The ultra-thin bezel on three sides of this streamlined display offers a virtually borderless visual experience, without distraction from the precise, gorgeous image. A sleek addition to any desktop.
21:9 UltraWide® Display
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
On-Screen Control
On-Screen Control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
AMD FreeSync™
With FreeSync*, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
Advanced Gaming Features
Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action.
Sleek Design
The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
  • 34" 21:9 WFHD (2560 x 1080) IPS Display
  • HDR 10
  • sRGB 99%
  • AMD FreeSync™ Technology
  • 3-Side Virtually Borderless Design
  • Tilt / Height Adjustable Stand
  • HDR 10
    To more fully realize content creators' vision, this monitor is compatible with industry-standard HDR10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
  • HDR Effect
    The HDR Effect helps transform non-HDR content into high-quality video that looks like HDR through its picture quality algorithm.
  • IPS with sRGB 99%
  • Virtually borderless design
    The ultrathin bezel on three sides of this streamlined display offers a virtually borderless visual experience, without distraction from the precise, gorgeous image.
  • 21:9 UltraWide display
  • On-Screen Control
  • AMD FreeSync
    With FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
  • Sleek design
    The sleek design of this LG premium monitor is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
LG 34WK650 - LED monitor - 34" - HDR
LED-backlit LCD monitor - 34"
Energy Class
Class G
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
37.8 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
UWFHD 2560 x 1080 at 75 Hz
Pixel Pitch
0.312 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Capable
HDR10
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
Voltage
AC 120/230 V
Black texture, white texture, silver hairline, textured silver
82.56 cm x 23 cm x 46.07 cm
7.6 kg
FCC Class B certified, UL, TUV, VCCI, cUL, CCC, DDC/CI, ERP, EPA 7.0, HDCP 2.2, HDCP 1.4
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
55 kWh
Diagonal Size
34"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.312 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
HDR Format
HDR10
Colour Support
Colour Gamut
99% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
40 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Photo Effect, Frame Rate Control (FRC), game mode, Cinema Mode, Mega Dynamic Contrast Ratio, CustomColor Mode, Vivid Color, FPS Mode, Crosshair Display, Flicker Safe, Reader Mode, SIX Axis Control, RTS Mode, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, split screen 2.0, My Display Preset, Color Weakness Mode, Original ratio, One Click Stand, Super Resolution+, 99% sRGB colour gamut
82.56 cm x 23 cm x 46.07 cm - with stand
7.6 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI , DisplayPort , Headphones
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), key lock
Cable holder
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
37.8 W
37.8 kWh/1000h
Power Consumption HDR (On mode)
35.6 kWh/1000h
Power Consumption (Typical)
42 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 82.56 cm - depth: 23 cm - height: 46.07 cm - weight: 7.6 kg , Without stand - width: 82.56 cm - depth: 5.12 cm - height: 36.98 cm - weight: 5.9 kg
Shipping Width
94 cm
Shipping Depth
49 cm
Shipping Height
24 cm
Shipping Weight
11.2 kg
