LG 34WK500 34" 2560x1080 5ms HDMI UltraWide IPS LED Monitor
Quicklinx: DNDRWS00 Mfr#: 34WK500
21:9 UltraWide® Display
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
sRGB 99%
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
On-Screen Control
On-Screen Control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
AMD FreeSync™
With FreeSync*, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
Advanced Gaming Features
Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action.
Sleek Design
The sleek design of LG premium monitors is accentuated by the new ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance
  • Play games with optimized settings
    Game mode includes three sub-modes - FPS, RTS, and custom - for personalizing your gaming experience or optimizing your favorite game genres.
  • Clearer, smoother image
    Gamers can experience seamless, fluid movement during high-resolution, fast-paced games.
  • Versatile elegance
    The curved base is an elegant style statement that also enhances stability for dependable performance. The base can be adjusted to change the tilt and angle of the monitor for a more comfortable viewing experience.
LG 34WK500-P - LED monitor - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class A
Power Consumption (On mode)
37 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
UWFHD 2560 x 1080 at 75 Hz
Pixel Pitch
0.3108 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
2xHDMI
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Black textured back cover, black metal base, black front
82.9 cm x 20.9 cm x 46.07 cm
6.9 kg
FCC Class B certified, UL, TUV, cUL, EN 61000-3-3, EN55024, DDC/CI, EN 61000-3-2:2006, EN 60950-1:2006, EMC 2004/108/EC, LVD 2006/95/EC, EN55022:2006 Class B
Display Type
Energy Class
Class A
Diagonal Size
34"
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.3108 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean, UK English
Game mode, Mega Contrast, Mega Dynamic Contrast Ratio, Multiscan Support, On-screen Digital Controls, 4-screen split, Crosshair Display, Flicker Safe, Reader Mode, Mercury free, Smart Energy Saving technology, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), My Display Preset, 6-Axis Color Adjustments, 99% sRGB colour gamut
82.9 cm x 20.9 cm x 46.07 cm - with stand
6.9 kg
Audio
Speakers
2 x HDMI , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), ArcLine stand
1 x HDMI cable , 1 x audio cable
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
37 W
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 82.9 cm - depth: 20.9 cm - height: 46.07 cm - weight: 6.9 kg , Without stand - width: 82.9 cm - depth: 4.2 cm - height: 37 cm - weight: 6.1 kg
Shipping Width
94.7 cm
Shipping Depth
19 cm
Shipping Height
47.7 cm
Shipping Weight
9.6 kg
