LG 32UD99 32" 3840x2160 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: DNDKWS00 Mfr#: 32UD99
Diagonal Size: 31.5in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
Hurry, only 3 left in stock!
£774.93 ex VAT
£929.91 inc VAT
You Want to Enjoy More UHD Contents
More and more streaming videos come in 4K, you want to enjoy millions of 4K streaming videos in native 3840x2160 UHD 4K resolution. You can also review your 4K contents before uploading them. You can appreciate the amount of detail you can enhance as LG UHD 4K Monitor delivers the outcome of your work.
Meet the UHD 4K HDR 10 Monitor for the New Era
It is now the era of HDR (High Dynamic Range). Enjoy flawless gaming graphics and HDR video through 32UD99 Monitor that captures vibrancy of colours. HDR game titles are available for the latest gaming consoles such as Play Station 4 Pro and Xbox One S, and HDR streaming video services are just around the corner.
Brighter screen with richer colour depth
32UD99 can receive and show HDR contents with HDR10 format which is the HDR standard for PC. It can reproduce high dynamic range of peak brightness over 500nits and 95% of DCI-P3 wide colour gamut. It is much real big change in terms of picture quality comparing to conventional monitors.
Vibrant Saturation of Colours with HDR10 for PC
Connected to HDR-capable consoles (Xbox One S / PlayStation 4 Pro) or HDR-supported graphics card, users will enjoy punchier brightness and highlights with deeper shadows and silhouettes. Experience HDR games with lower input lag- fast and seamless.
Experience the HDR Effect
Even if your videos are not in HDR, you can still experience the HDR through the "HDR Effect" mode on 32UD99. It can transform average contents into HDR quality video through its picture quality algorithm including tone mapping and Ultra Luminance. Experience how SDR is transformed into HDR.
The LG IPS Monitor
The LG IPS Monitors ensures an awesome picture quality that provides clear images and vivid colours from any angle. Colour Calibration tests will be conducted before each product is handed over to you. Now you can enjoy the life-like colours of 4K images on LG IPS UHD 4K Monitor
4 Side Borderless Design & Slim ArcLine Stand
Extremely thin bezel on four sides of the display offers a borderless visual experience. Slim ArcLine designed stand lets you experience the state-of-the-art viewing in various settings.
Hardware Calibration-Ready
With 32UD99 capable of Hardware Calibration through True Colour Pro software, you can enjoy the colour performance of LG IPS 4K screen that allows 95% of DCI-P3 colour performance and impeccable consistency.
Hassle-Free with Only 1 Cable : USB Type-C™
Display Connection transfers data and charge a laptop or mobile device, all at the same time using a single cable with USB Type-C™, all-in-one connection for more convenience.
Easy User Interface with OnScreen Control 2.0
Every step of installing and controlling is easy without any hassle. OnScreen Control S/W (2.0) allows you adjust customize all the display options with a few clicks including pivot control.
Multiple Screen Split Options
Through OnScreen Control Software, select most needed screen setting among 14 of Screen Split options and optimize Multi-tasking Windows organization and screen real estate use.
Easy Control of Pivoted Ergonomic Stand
Maximize work efficiency of graphic works on vertical frames such as web editing and blogging. Simply rotate the screen as needed and view the display without scrolling. The height adjustment feature adds convenience. OnScreen Control S/W allows you to adjust and customize all the display options with a few clicks including pivot control.
Multi-Dimensional Experience with Rich Bass
32UD99 delivers unparalleled immersive experience through the built-in speakers with Rich Bass. Enjoy three dimensional sound resonating from your monitor.
  • IPS
    Outstanding performance is assured by the specially designed display panel with in-plane switching (IPS), delivering accurate colors that remain consistent at wide viewing angles.
  • HDR 10
    To more fully realize content creators' vision, this monitor is compatible with industry-standard HDR 10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
  • USB Type-C
    USB Type-Cports allow video display, data transfer and laptop/mobile device charging, all at the same time over a single cable. Reduce cord clutter and increase efficiency with USB Type-C.
  • Virtually borderless design
    The ultra-thin bezel on four sides of this streamlined display offers a virtually borderless visual experience, without distraction from the precise, gorgeous image. A sleek addition to any desktop.
  • Bluetooth audio with rich bass
    With a simple, Bluetooth connection between a mobile device and the monitor's built-in speaker, enjoy the music that's stored on devices with more powerful, vivid sound quality.
LG 32UD99 - LED monitor - 4K - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class B
Energy Consumption per Year
58 kWh
Power Consumption (On mode)
40 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.18159 mm
Brightness
350 cd/m²
Contrast Ratio
1300:1
Response Time
5 ms (grey-to-grey)
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare, 3H Hard Coating
White (back), silver spray front and base, white/silver spray stand
71.38 cm x 25.92 cm x 48.54 cm
8.4 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, CB, DDC/CI, RoHS, REACH, KC, ERP, EPA
Display Type
Energy Class
Class B
58 kWh
40 W
Diagonal Size
31.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.18159 mm
Brightness
350 cd/m²
Contrast Ratio
1300:1
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Korean
SUPER + Resolution, Black eQualizer, On-screen Digital Controls, TrueColor Pro, Flicker Safe, Reader Mode, SIX Axis Control, PBP, Factory Calibration, DICOM Simulation, Dual Controller, DAS Mode (Dynamic Action Sync), FreeSync Technology, Mega DFC, DCI-P3 95% (CIE 1976) Color Gamut, Rich Bass, 4 Side Borderless Design
71.38 cm x 25.92 cm x 48.54 cm - with stand
8.4 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI (HDCP) , DisplayPort (HDCP) , USB-C , Headphones , 2 x USB downstream
Mechanical
Tilt Angle
-5/+20
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
ArcLine stand
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C cable - 1.8 m , 1 x USB-A to USB-C adapter
Power Consumption Sleep
1.2 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 71.38 cm - depth: 25.92 cm - height: 48.54 cm - weight: 8.4 kg , Without stand - width: 71.38 cm - depth: 4.46 cm - height: 41.02 cm - weight: 6.5 kg
LG 32UD99 32 Bundle deal on LG 32UD99 32" 3840x2160 5ms HDMI DisplayPort USB-C IPS LED Monitor
£874.10
Response Time: 5ms
Interfaces: HDMI
Interfaces: USB-C
Brand: LG
Price Range Ex VAT: 750 - 1000
