LG 32UD59 32" 3840x2160 4ms HDMI DisplayPort LED Monitor
Quicklinx: DNDDWS00 Mfr#: 32UD59
32 Inch 4K UHD
Outstanding Ultra HD performance is assured by the specially designed 4K display, delivering accurate colors that remain consistent with four times the resolution of Full HD.
DCI-P3 95% Color Gamut
This monitor covers 95% of the DCI-P3 color space, the current standard utilized by the film industry, assuring an exceptionally wide range of available colors.
HDCP 2.2 Compatible
Connect with confidence: This LG 4K monitor is compatible with the latest HDCP 2.2 copy protection, so it will display video from 4K streaming services, game consoles and Ultra HD Blu-ray disc players.
AMD FreeSync Technology
LG's monitors with AMD FreeSync technology reduce the tearing and stuttering that occur between a graphic card’s frame rate and a monitor’s refresh rate. Thanks to FreeSync, gaming enthusiasts can experience seamless, fluid movement throughout any hi-res, heavy-duty game.
Dynamic Action Sync
Gamers can experience optimized, fast-pace gaming with Dynamic Action Sync. Dynamic Action Sync is a feature that minimizes input lag so the game play in RTS games is more responsive.
Black Stabilizer
Keep visibility even in dark scenes. LG's Black Stabilizer senses dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark.
On-Screen Control
On-Screen Control puts a host of monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller can be adjusted with just a few clicks of the mouse.
Screen Split
Customize your monitor layout for multitasking with the latest version of LG Screen Split. Resize and display multiple windows at once, with 14 options including four different picture-in-picture (PIP) choices.
Height Adjustable Display
Find your perfect viewing angle: The adjustable stand allows users to raise and lower the monitor as desired to provide the best possible view.
  • DCI-P3 95% color gamut
  • HDCP 2.2 compatible
  • AMD FreeSync technology
    LG's monitors with AMD FreeSync technology reduce the tearing and stuttering that occur between a graphic card's frame rate and a monitor's refresh rate. Thanks to FreeSync, gaming enthusiasts can experience seamless, fluid movement throughout any hi-res, heavy-duty game.
  • Dynamic action sync
  • Black stabilizer
    Keep visibility even in dark scenes. LG's black stabilizer senses dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark.
  • On-screen control
    On-screen control puts a host of monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and dual controller can be adjusted with just a few clicks of the mouse.
  • Screen split
  • Height adjustable display
LG 32UD59-B - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class A
Energy Consumption per Year
58 kWh
Power Consumption (On mode)
40 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.181 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Gamut
95% DCI-P3
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Matte black
72.81 cm x 23.68 cm x 45.82 cm
7.1 kg
FCC Class B certified, UL, CB, DDC/CI, KC, ERP, EPA 7.0
3-year warranty
Display Type
Energy Class
Class A
58 kWh
Diagonal Size
32"
Viewable Size
31.5"
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.181 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Gamut
95% DCI-P3
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, SUPER + Resolution, On-screen Digital Controls, blue light reduction, Flicker Safe, Smart Energy Saving technology, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), colour adjustment mode
Matte black
72.81 cm x 23.68 cm x 45.82 cm - with stand
7.1 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI , DisplayPort , Headphones
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
Input Voltage
40 W
Power Consumption (Typical)
50 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 72.81 cm - depth: 23.68 cm - height: 45.82 cm - weight: 7.1 kg , Without stand - width: 72.81 cm - depth: 4.99 cm - height: 42.46 cm - weight: 5.3 kg
Limited warranty - 3 years
