LG 32MP58HQ-P 31.5" 1920x1080 5ms VGA HDMI AH-IPS LED Monitor
Quicklinx: D5PNWS00 Mfr#: 32MP58HQ-P
The LG IPS Monitor ensures and awesome picture quality that provides clear images and vivid colors from any angle for your viewing pleasure.
The Sleek Cut design, the remarkable reduction of depth with body frame, adds sophisticated ambience for your place.
Flicker Safe and Reader mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
  • Vivid colours from any angle, LG IPS
    The LG IPS Monitor ensures and awesome picture quality that provides clear images and vivid colours from any angle for your viewing pleasure.
  • Sleek Cut design
  • Protect your eyes and view in comfort
    Flicker Safe and Reader mode help maximise visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
  • Offers improved colour vision to colour weakness
    Colour revision algorithms are used to help those with colour weakness who have difficulty distinguishing certain ranges of colours can view all the important content.
LG 32MP58HQ-P - LED monitor - Full HD (1080p) - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class A
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
36 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.363 mm
Brightness
250 cd/m²
Contrast Ratio
1200:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
3H Hard Coating
Voltage
High-gloss piano lacquer black
72.66 cm x 20.48 cm x 49.19 cm
6.5 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, RoHS, EPA 6.0, IEC 62087 Edition 2
Display Type
Energy Class
Class A
52 kWh
Diagonal Size
31.5"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.363 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 63 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
Backlight Technology
WLED
OSD Languages
German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean, UK English
SUPER + Resolution, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, Mercury free, 6-axis colour adjustment, Black Stabilizer, Intelligent Auto, My Display Preset, Sleek Cut Design, Color Weakness Mode
72.66 cm x 20.48 cm x 49.19 cm - with stand
6.5 kg
VGA , HDMI (HDCP) , Headphones
Mechanical
Tilt
Tilt Angle
-2/+10
VESA Mounting Interface
200 x 100 mm
1 x VGA cable
Input Voltage
36 W
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 72.66 cm - depth: 20.48 cm - height: 49.19 cm - weight: 6.5 kg , Without stand - width: 72.66 cm - depth: 9.41 cm - height: 43.01 cm - weight: 6 kg
Sustainability Information
ENERGY STAR Certified
