LG 32LW340C 32" 1920x1080 LED Commercial Pro TV
Quicklinx: CSTJWS00 Mfr#: 32LW340C
  • 1080p
LG Public Display TV's are designed to enhance any business application. The LW340C has a simple user-friendly interface, superb images and video that helps facilitate any communications between businesses and their target audiences.
PUBLIC DISPLAY MODE
From channel selection to energy-saving features, Public Display Mode allows you to control the TV settings in your business area, prevent misuse by customers, set volume limits, or restore factory defaults on any TV. You are in control of it all.
USB CLONING
The USB Cloning feature allows you to simply copy the TV settings onto all TVs using a USB stick, a process that is fully automated to save time without having to set each TV one by one.
WELCOME SCREEN
Welcome visitors with a warm greeting message that includes your business name/logo and now with a video or both.
LOCK MODE
The Lock Mode blocks external input signals for illegal communication, a useful feature for preventing misuse of TVs in facilities such as prisons, mental hospitals and other applicable public spaces.
EXTERNAL SPEAKER OUT
Enhance the entertainment experience by adding an additional speaker, visitors to listen to and control the TV audio from anywhere in your business area, including restrooms.
LG Commercial Lite 32LW340C 32" LED-backlit LCD TV - Full HD - for hotel / hospitality
LED-backlit LCD TV
Diagonal Class
32"
Commercial Use
Yes - hotel / hospitality
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
60 Hz Frame Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
VGA (HD-15)
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-S2, DVB-T2
Commercial Features
Screen welcome message, prison mode, Remote Diagnosis, Lock Mode
Settings Cloning Capability
Speaker System
2 speakers
USB
Remote control
Voltage
Energy Class
Class A+
Power Consumption (On mode)
30 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
44 kWh
73.3 cm x 7.22 cm x 43.6 cm
LED-backlit LCD TV
Energy Class
Class A+
30 W
44 kWh
Diagonal Class
32"
Commercial Use
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
Modes
Expert mode, hotel mode
Dimensions
Without stand
73.3 cm
7.22 cm
43.6 cm
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
60 Hz Frame Rate
Direct-lit LED
Brightness
300 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Backlight Life
50,000 hour(s)
Commercial Features
XD Engine technology, Eco Flower, One Channel Map, security lock slot (cable lock sold separately), RJP Compatible
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Conditional Access
Common Interface (CI) slot
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Digital TV Service
TNT HD
Video Features
Teletext
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
DivX HD
Supported Audio Formats
MP3, PCM, AC3, AAC, HE-AAC, E-AC3
Supported Pictures Formats
MPO, JPS, JPEG
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Clear Voice technology, Invisible Speaker System
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
Supported Consumer Electronics Control (CEC)
Simplink
Connector Type
Speakers output , Headphones , Composite video / component video input , VGA input , 2 x HDMI input , Serial input , Digital audio output (optical) , LAN , USB 2.0
CB, EMC, RoHS, CEC, ERP, CU-TR
Power supply
Input Voltage
0.3 Watt
Smart energy saving
Dimensions & Weight Details
Panel without stand - 73.3 cm x 7.22 cm x 43.6 cm , Panel with stand - 73.3 cm x 28.2 cm x 49 cm x 8.17 kg
Width (Shipping)
81.2 cm
Depth (Shipping)
19 cm
Height (Shipping)
52 cm
