LG 32LJ510B 32" HD LED TV
Quicklinx: CV8LWS00 Mfr#: 32LJ510B
  • DVB-T
32" LG HD LED TV
Key Features
Picture Mastering Engine
Improve any image with Resolution Upscaler
Virtual Surround Sound
USB Connectivity
Built-In Games
  • Improve any image with Resolution Upscaler
    Enjoy any image with LG's Resolution Upscaler, which enhances and optimizes the image no matter the picture quality.
  • Virtual surround sound
    High-quality TV creates a surround sound effect, producing virtual audio channels for broadcast and digital programs. Surround your senses with sound from all angles.
  • USB connectivity
    Simply insert a USB stick or external hard drive, containing videos, photos and music into the USB port to play and view the files.
  • Convenient connectivity
    Plug and Play. With multiple inputs you can plug in your HDMI cable or USB and play out your entertainment, games or digital devices through your TV.
LG 32LJ510B 32" LED TV
LED-backlit LCD TV
Diagonal Class
32"
Resolution
1366 x 768
Display Format
720p
Motion Enhancement Technology
300 Hz Picture Mastering Index
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
LAN
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-C, DVB-T
Picture Enhancements
Resolution Upscaler, Color Master Engine
Sound Effects
Virtual Surround Mode
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A+
Power Consumption (On mode)
29 W
Energy Consumption per Year
40 kWh
73.9 cm x 8.4 cm x 44.1 cm
4.85 kg
LED-backlit LCD TV
Energy Class
Class A+
29 W
40 kWh
Diagonal Class
32"
TV Tuner Presence
Video Interface
HDMI Ports Qty
2 ports
Dimensions
Without stand
73.9 cm
8.4 cm
44.1 cm
4.85 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
200 x 200 mm
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Digital TV Tuner
Digital TV Tuner
DVB-C, DVB-T
Video Features
Teletext
Teletext Memory
2000 pages
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
HEVC
Supported Audio Formats
MP3, WMA, PCM, AC3, AAC, HE-AAC, E-AC3, MP2
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Surround Mode
Sound Effects
Output Power / Total
10 Watt
Clear Voice technology
Network & Internet Multimedia
LAN
Supported Consumer Electronics Control (CEC)
Simplink
Connector Type
2 x HDMI , USB , Composite video / component video input , Network , Digital audio output (optical)
Batteries
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Energy save
Dimensions & Weight Details
Panel without stand - 73.9 cm x 8.4 cm x 44.1 cm x 4.85 kg , Panel with stand - 73.9 cm x 16.8 cm x 47.2 cm x 4.9 kg
