LG 29UM69G 29" 2560x1080 1ms HDMI DisplayPort USB-C UltraWide IPS LED Monitor
Quicklinx: DNDQWS00 Mfr#: 29UM69G
Gaming Monitor with 1ms Motion Blur Reduction
Now gamers can achieve superb gaming graphics through the long-awaited combination of 21:9 UltraWide IPS and 1ms Motion Blur Reduction.
Fluid Gaming Motion: AMD FreeSync Technology
You can play without a frame loss with AMD FreeSync Technology, which eliminates tearing and stuttering that occur from the difference between a graphics card’s frame rate and monitor’s refresh rate.
A Variety of Gaming Features to Win: DAS Mode
The Dynamic Action Sync mode allows users to instantly attack the opponent without delay. It synchronizes your senses with real-time scenes happening in a fast-paced game by minimizing input lag. without delay. It synchronizes your senses with real-time scenes happening in a fast-paced game by minimizing input lag.
Gaming Features to Win: Black Stabilizer
While playing shooting games, the Black Stabilizer gives gamers full visibility even in deep-dark scenes. It automatically senses the darkest side and makes it brighter so that you can find the enemies hiding and waiting to attack you in the dark.
A Variety of Gaming Fetures to Win: Game Mode
With the Game Mode option in Picture Mode, you can customize the picture quality for various gaming genres such as FPS Game1, FPS Game2, RTS Game and Custom Game.
The Mighty Design of The Monitor
LG’s Gaming Monitor has design features thatfit well into your gaming station setup without hindering your gaming. The mighty design of the monitor with V-line stand and red colour produces a space where the gamer can be immersed deep into the game.
LG 29UM69G - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class G
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
25.8 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
UW-UXGA 2560 x 1080 at 75 Hz
Pixel Pitch
0.2628 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey), 14 ms (typical)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB (CIE 1931)
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
High glossy black
70.25 cm x 20.41 cm x 41.5 cm
5.5 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, CCC, DDC/CI, ERP, EPA 7.0
Display Type
Energy Class
Class G
41 kWh
Diagonal Size
29"
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2628 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB (CIE 1931)
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
33 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Ukrainian, English, German, French, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
HDCP, SUPER + Resolution, game mode, Cinema Mode, Mega Dynamic Contrast Ratio, FPS Mode, 4-screen split, Crosshair Display, Flicker Safe, Reader Mode, SIX Axis Control, RTS Mode, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, Color Weakness Mode, 1ms Motion Blur Reduction
High glossy black
70.25 cm x 20.41 cm x 41.5 cm - with stand
5.5 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
HDMI , DisplayPort , USB-C , Headphones
Mechanical
Height, tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
Cable holder
1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
25.8 W
25.8 kWh/1000h
Power Consumption (Typical)
35 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 70.25 cm - depth: 20.41 cm - height: 41.5 cm - weight: 5.5 kg , Without stand - width: 70.25 cm - depth: 6.38 cm - height: 32.84 cm - weight: 5 kg
