Product
LG 29UM68-P 29" 2560x1080 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: C0MRWS00 Mfr#: 29UM68
21:9 UltraWide™ FHD on IPS Display
"21:9 UltraWide™ FHD (2560*1080) display offers visual comfort and ensures your best viewing pleasure. There is no color shift or no distortion of color at all."
The Beauty of ArcLine
Inspired by the beauty and power of nature, the ArcLine completes the design with a refined aesthetic flair.
UltraWide™ FOV Meets FreeSync
Experience fluid motion play on the 21:9 UltraWide™’s generous field of view without screen tearing or stuttering.
Game Mode
"Game Mode, consisting of FPS, RTS, and Custom modes, provides a customized gaming experience that varies with genres."
Fully Geared UP with Winning Features
Black Stabilizer is especially useful to detect objects including enemies that are hiding in dark areas. Dynamic Action Sync allows you to attack enemies faster with less lag time.
Flawless Color Expression
"You are guaranteed an immersive artwork through a sRGB over 99% color space.Color calibration tests are conducted on the production line to ensure color accuracy. "
Up-scaled Work Efficiency
Screen Split and PIP Mode bring you to be the real multi-tasker.
Exceptional Usability
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
  • 21:9 UltraWide Full HD IPS display
    The UltraWide 21:9 aspect ratio makes games and movies more immersive than ever. The clarity of 1080p pixel Full HD resolution with IPS is a game-changer. Simply put, from any viewing angle, everything looks more crisp and detailed in Full HD.
  • sRGB over 99%
    sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this monitor is a great solution for gamers, professional photographers, graphic designers or anyone looking for highly accurate color.
  • On-screen control
    On-screen control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
  • Screen Split 2.0
    Customize your monitor layout for multitasking with the latest version of LG Screen Split. Resize and display multiple windows at once, with 14 options including four different picture-in-picture (PIP) choices.
  • FreeSync
    LG's 21:9 UltraWide monitors with FreeSync¹ technology eliminate the tearing and stuttering that have plagued gaming enthusiasts for years.
  • Game mode
    Dedicated game modes assure optimal viewing conditions. Included are a total of three different preset game modes: two first-person shooter modes plus a real-time strategy mode. Choose the right mode for the game you're playing.
  • Advanced gaming features
    Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action.
  • Arcline design
    The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
LG 29UM68-P - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class B
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32 W
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Input Connectors
2xHDMI, DisplayPort
70.25 cm x 20.47 cm x 41.4 cm
5.4 kg
Plug and Play
3-year warranty
Display Type
Energy Class
Class B
47 kWh
32 W
Diagonal Size
29"
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080
Brightness
250 cd/m²
Contrast Ratio
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
Picture Mode, Auto Resolution, 99% Adobe RGB colour gamut, On-screen Digital Controls, 4-screen split, Mercury free, MaxxAudio, Black Stabilizer
70.25 cm x 20.47 cm x 41.4 cm - with stand
5.4 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI , DisplayPort , Headphones
Mechanical
Flat Panel Mount Interface
75 x 75 mm
Plug and Play
Security Slot Type
Kensington security slot
31 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 70.25 cm - depth: 20.47 cm - height: 41.4 cm - weight: 5.4 kg , Without stand - width: 70.25 cm - depth: 6.38 cm - height: 32.84 cm - weight: 4.8 kg
Limited warranty - 3 years
