Efficiently run several programs and have multiple active windows on the screen at the same time.
For business meetings, the Dual link-up feature allows two portable devices, such as a computer, camera, phone or Blu-ray player to be connected to the monitor and used on a single screen simultaneously.
LG's smart energy saving mode reduces power consumption without lowering the brightness of the monitor.
- LG 29UB67-B - LED monitor - 29"
- LED-backlit LCD monitor - 29"
- Energy Class
- Class G
- Energy Consumption per Year
- 62 kWh
- Power Consumption (On mode)
- 43 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- 2560 x 1080 at 60 Hz
- Pixel Pitch
- 0.264 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- 2xHDMI, DVI-D, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 70.3 cm x 25.23 cm x 40.4 cm
- 8.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, UL, TUV GS, cUL, EN 61000-3-3, EN55024, DDC/CI, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EPA 6.0, EMC 2004/108/EC, EN55022:2006 Class B, DIN ISO 9241-307
- Display Type
- Energy Class
- Class G
- 62 kWh
- Diagonal Size
- 29"
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 56 - 61 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Power off timer, Multiscan Support, 4-screen split, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, Smart Energy Saving technology, Color Calibrated, Dual Controller, 99% sRGB colour gamut
- Matte black
- 70.3 cm x 25.23 cm x 40.4 cm - with stand
- 8.6 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 7 Watt
- 2 x HDMI , DVI-D (HDCP) , DisplayPort , Audio line-in , Audio line-out
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 200 x 100 mm
- Cables Included
- 1 x audio cable , 1 x HDMI cable
- Backlight Life
- 50,000 hours
- Power Supply
- Internal
- Input Voltage
- 43 W
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption (Typical)
- 46 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 70.3 cm - depth: 25.23 cm - height: 40.4 cm - weight: 8.6 kg , Without stand - width: 70.3 cm - depth: 6.2 cm - height: 32.12 cm - weight: 6.3 kg
Sustainability Information
- ENERGY STAR Certified
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £15.80 |
