LG 29" Black Full HD LED Monitor 2560 x 1080 2x 5W Speaker Dis
Quicklinx: C41QWS00 Mfr#: 29UB67-B
Efficiently run several programs and have multiple active windows on the screen at the same time.
For business meetings, the Dual link-up feature allows two portable devices, such as a computer, camera, phone or Blu-ray player to be connected to the monitor and used on a single screen simultaneously.
LG's smart energy saving mode reduces power consumption without lowering the brightness of the monitor.
LG 29UB67-B - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class G
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
43 W
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
Matte black
70.3 cm x 25.23 cm x 40.4 cm
8.6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, cUL, EN 61000-3-3, EN55024, DDC/CI, Directive 2006/95/EC, EN 61000-3-2:2006, EN 60950-1:2006, EPA 6.0, EMC 2004/108/EC, EN55022:2006 Class B, DIN ISO 9241-307
Display Type
Energy Class
Class G
62 kWh
Diagonal Size
29"
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.264 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Power off timer, Multiscan Support, 4-screen split, Flicker Safe, Reader Mode, Dual Link-up, SIX Axis Control, Smart Energy Saving technology, Color Calibrated, Dual Controller, 99% sRGB colour gamut
Matte black
70.3 cm x 25.23 cm x 40.4 cm - with stand
8.6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
7 Watt
2 x HDMI , DVI-D (HDCP) , DisplayPort , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
200 x 100 mm
1 x audio cable , 1 x HDMI cable
Backlight Life
50,000 hours
Power Supply
Internal
Input Voltage
43 W
26 kWh/1000h
Power Consumption (Typical)
46 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 70.3 cm - depth: 25.23 cm - height: 40.4 cm - weight: 8.6 kg , Without stand - width: 70.3 cm - depth: 6.2 cm - height: 32.12 cm - weight: 6.3 kg
Sustainability Information
ENERGY STAR Certified
C41Q C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £12.92
