LG 27UK600 27" 3840x2160 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: DN9BWS00 Mfr#: 27UK600
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI
£364.09 ex VAT
£436.90 inc VAT
To fully realize content creators' vision, this monitor is compatible with HDR10 high dynamic range, supporting specific levels of color and brightness that exceed the capabilities of ordinary monitors.
The HDR Effect helps transform non-HDR content into high quality video that looks like HDR through its picture quality algorithm.
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
  • HDR 10
  • HDR Effect
  • sRGB
  • AMD FreeSync
    With FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. FreeSync virtually eliminates screen tearing and stuttering.
  • Gaming features
    Serious gaming features for serious gamers. Quickly optimize monitor settings to activate Black Stabilizer to reveal superior detail in dark scenes while the Dynamic Action Sync feature assures smooth, fluid gaming action.
  • On-Screen Control
    On-Screen Control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and Dual Controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
  • Ergonomic Stand
    The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
LG 27UK600-W - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
450 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Textured black, silver (stand), white (back)
61.31 cm x 20.94 cm x 45.52 cm
5.2 kg
Plug and Play, FCC Class B certified, UL, TUV, VCCI, cUL, DDC/CI, RoHS, REACH, KC, ERP, EPA 7.0, DisplayPort 1.2
Display Type
Energy Class
Class A
44 kWh
30 W
Diagonal Size
27"
Viewable Size
27"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Brightness
450 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
sRGB colour management, On-screen Digital Controls, Flicker Safe, Reader Mode, SIX Axis Control, Factory Calibration, Dual Controller, DAS Mode (Dynamic Action Sync), 99% sRGB (CIE 1931) colour gamut, HDR (high dynamic range), Super Resolution+
61.31 cm x 20.94 cm x 45.52 cm - with stand
5.2 kg
2 x HDMI (HDCP) , DisplayPort (HDCP) , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
45 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.31 cm - depth: 20.94 cm - height: 45.52 cm - weight: 5.2 kg , Without stand - width: 61.31 cm - depth: 7.3 cm - height: 36.44 cm - weight: 4.7 kg
Shipping Width
69.4 cm
Shipping Depth
14.8 cm
Shipping Height
43.6 cm
Shipping Weight
7.5 kg
LG 27UK600 27 Bundle deal on LG 27UK600 27" 3840x2160 5ms HDMI DisplayPort IPS LED Monitor
£463.26
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Brand: LG
Price Range Ex VAT: 300 - 500
