Display video, transfer data and charge a laptop or mobile device, all at the same time using a single cable with USB-C. On-screen control makes it easy to adjust many monitor settings via an on-screen window, with a few easy clicks of your mouse. Keep visibility even in dark scenes. LG's Black Stabilizer sense dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark. The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
- LG 27UD88 - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 44 kWh
- Power Consumption (On mode)
- 30 W
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1554 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Gamut
- 99% sRGB
- Input Connectors
- 2xHDMI, DisplayPort, USB
- Height, pivot (rotation), tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Silver, white (back)
- 61.5 cm x 20.54 cm x 42.51 cm
- 6 kg
- Plug and Play, FCC Class B certified, UL, cUL, CB, DDC/CI, RoHS, REACH, KC, EPA
- Display Type
- Energy Class
- Class A
- 44 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1554 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Gamut
- 99% sRGB
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 61 Hz
- Horizontal Refresh Rate
- 30 - 135 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Picture in picture, HDCP, game mode, On-screen Digital Controls, TrueColor Pro, 4-screen split, Flicker Safe, Smart Energy Saving technology, Color Wizard, Black Stabilizer, DAS Mode (Dynamic Action Sync), 99% sRGB colour gamut
- 61.5 cm x 20.54 cm x 42.51 cm - with stand
- 6 kg
- 2 x HDMI , DisplayPort , 2 x USB 3.0 downstream , Headphones , USB-C
Mechanical
- Tilt Angle
- -2/+20
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB cable , 1 x DisplayPort cable , 1 x HDMI cable
- 30 W
- Power Consumption (Typical)
- 29 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- OS Required
- Windows 10
- Dimensions & Weight Details
- With stand - width: 61.5 cm - depth: 20.54 cm - height: 42.51 cm - weight: 6 kg , Without stand - width: 61.5 cm - depth: 4.27 cm - height: 36.51 cm - weight: 4.6 kg
- 0 °C
- 40 °C
- 0 - 80%
