Product
Brand
LG 27UD88 27" 3840 x 2160 5ms HDMI LED Silver/White
Quicklinx: CXPZWS00 Mfr#: 27UD88
Display video, transfer data and charge a laptop or mobile device, all at the same time using a single cable with USB-C. On-screen control makes it easy to adjust many monitor settings via an on-screen window, with a few easy clicks of your mouse. Keep visibility even in dark scenes. LG's Black Stabilizer sense dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark. The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
LG 27UD88 - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Input Connectors
2xHDMI, DisplayPort, USB
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare, 3H Hard Coating
Silver, white (back)
61.5 cm x 20.54 cm x 42.51 cm
6 kg
Plug and Play, FCC Class B certified, UL, cUL, CB, DDC/CI, RoHS, REACH, KC, EPA
Display Type
Energy Class
Class A
44 kWh
30 W
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Picture in picture, HDCP, game mode, On-screen Digital Controls, 99% sRGB colour gamut, TrueColor Pro, 4-screen split, Flicker Safe, Smart Energy Saving technology, Color Wizard, Black Stabilizer, DAS Mode (Dynamic Action Sync)
61.5 cm x 20.54 cm x 42.51 cm - with stand
6 kg
2 x HDMI , DisplayPort , 2 x USB 3.0 downstream , Headphones , USB-C
Mechanical
Tilt Angle
-2/+20
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
1 x USB cable , 1 x DisplayPort cable , 1 x HDMI cable
29 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 61.5 cm - depth: 20.54 cm - height: 42.51 cm - weight: 6 kg , Without stand - width: 61.5 cm - depth: 4.27 cm - height: 36.51 cm - weight: 4.6 kg
0 - 80%
