IPS (In-Plane Switching) technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
On-screen control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and dual controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor.
Full HD IPS display
IPS (In-Plane Switching) technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle. -
On-screen control
On-screen control puts a host of essential monitor settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split 2.0 and dual controller and more can now be adjusted with just a few clicks of the mouse, instead of hard buttons on the monitor. -
Screen split 2.0
Customize your monitor layout for multitasking with the latest version of LG screen split. Resize and display multiple windows at once, with 14 options including four different picture-in-picture (PIP) choices. -
Reader mode
Reducing blue light to help lessen eye fatigue, Reader Mode provides optimal conditions for reading. With just a click of a mouse, you can more comfortably read your display.
- LG 27MP38VQ-B - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Input Connectors
- HDMI, DVI, VGA
- Voltage
- AC 120/230 V
- Dimensions (WxDxH) - without stand
- 64.14 cm x 4.82 cm x 39.3 cm
- 3.9 kg
- Plug and Play, DDC/CI
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 34 kWh
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- OSD Languages
- Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
- SUPER Energy Saving Technology, 4-screen split, Multilingual On Screen Display
- 64.14 cm x 4.82 cm x 39.3 cm - without stand
- 3.9 kg
- VGA , HDMI , DVI-D , Headphones
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Input Voltage
- AC 120/230 V
- 23 W
- Power Consumption (Typical)
- 27 Watt
- 0.3 Watt
- Dimensions & Weight Details
- Without stand - width: 64.14 cm - depth: 4.82 cm - height: 39.3 cm - weight: 3.9 kg , With stand - width: 64.14 cm - depth: 20.3 cm - height: 45.97 cm - weight: 4.4 kg
- Limited warranty - 3 years
StarTech.com Dual Monitor Mount - Stackable | In Stock | £227.08 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.49 |
StarTech.com Monitor Desk Mount - Steel | In Stock | £50.26 |
