LG 27MD5KA 27" 5120x2880 14ms HDMI DisplayPort USB-C Thunderbolt Ultra HD IPS LED Monitor
Quicklinx: DNDBWS00 Mfr#: 27MD5KA-B.AEK
Diagonal Size: 27in
Max Resolution: 5120 x 2880
Response Time: 14ms
Speakers: Speaker(s)
Interfaces: Thunderbolt 3
£951.49 ex VAT
£1,141.78 inc VAT
Ultra Clear 218 PPI 5K Display
At 218 pixels per inch to deliver 5K resolution (5120 x 2880 at 27") the LG UltraFine™ 5K display lets you experience the definition and detail of a Mac on a large 5K screen.
Rich Color, Better Detail
A color spectrum of P3 99% enables you to edit your high-resolution photos precisely. You will experience exceptional detail and rich color on this 5K display.
5K Display with Thunderbolt™ 3
The LG UltraFine™ 5K display with Thunderbolt™ 3 port can transmit 5K video and data while simultaneously charging a new MacBook Pro (up to 85W) over a single cable. Plus, three USB-C downstream ports (USB 5 Gbps) let you connect additional devices as needed.
Ultimate Visibility
The LG UltraFine™ 5K display reaches a brightness of 500cd/m² and can express a wide range of color and contrast. You can experience vivid, lifelike images on a 5K screen, which provides a more natural representation.
Consistent Color and Clarity
This 5K high-definition monitor with IPS minimizes color shift and delivers detailed, accurate images on the UltraFine™ 5K screen. Color is consistent from edge to edge.
Clear Communication and Entertainment
The LG UltraFine™ 5K display has an internal webcam and responsive speakers/microphone that are perfectly suited to entertainment and communication, allowing you to watch movies, and video chat.
Easy Display Control with macOS
Detailed control of display settings such as brightness can be done using macOS without the need to use any physical buttons.
Multi-Function Screen Manager
The LG Screen Manager has been optimized for macOS to provide a variety of multi-screen options. For example, it can automatically divide the screen into two to four frames, according to users’ specific needs.
Convenient Adjustable Display Stand
LG UltraFine™ 5K displays have convenient height/tilt adjustment. Users can customize the display height to create a more personal, comfortable workstation, or easily wall-mount the display with the use of a VESA mount bracket.
  • 5K (5120 x 2880) IPS Display
  • 218 Pixel Per Inch
  • P3 99% Color Spectrum
  • Built-In Camera & Speaker
  • Thunderbolt™3
LG UltraFine 27MD5KA-B - LED monitor - 5K - 27"
LED-backlit LCD monitor - 27"
Microphone, camera, USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
5K 5120 x 2880 at 60 Hz
Pixel Pitch
0.11685 mm
Brightness
500 cd/m²
Contrast Ratio
1100:1
Response Time
14 ms (grey-to-grey)
Input Connectors
Thunderbolt 3
Display Position Adjustments
Height, tilt
Screen Coating
Anti-reflective, 2H Hard Coating
Non-glossy black
62.56 cm x 23.99 cm x 46.44 cm
8.5 kg
FCC Class B certified, UL, VCCI, BSMI, cUL, CCC, RoHS, REACH, KC, RCM, EPA 7.0, HDCP 2.2, HDCP 1.4
Display Type
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.11685 mm
Pixel Per Inch
218
Brightness
500 cd/m²
Contrast Ratio
1100:1
Response Time
Vertical Refresh Rate
48 - 60 Hz
Horizontal Refresh Rate
30 - 178 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
4-screen split, DCI-P3 99% (CIE 1931) Color Gamut
Non-glossy black
62.56 cm x 23.99 cm x 46.44 cm - with stand
8.5 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
Thunderbolt 3 / USB-C , 3 x USB-C downstream
Mechanical
Height, tilt
Tilt Angle
- 5/+25
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), ambient light sensor
VESA cover
1 x Thunderbolt 3 / USB-C cable
Security Slot Type
Kensington security slot
140 Watt
Power Consumption Sleep
1.2 Watt
Power Consumption (Off Mode)
0.5 Watt
Included Software
LG Screen Manager
Dimensions & Weight Details
With stand - width: 62.56 cm - depth: 23.99 cm - height: 46.44 cm - weight: 8.5 kg , Without stand - width: 62.56 cm - depth: 5.38 cm - height: 37.51 cm - weight: 6.4 kg
Shipping Width
74.3 cm
Shipping Depth
31.5 cm
Shipping Height
58 cm
Shipping Weight
13.5 kg
LG 27MD5KA 27 Bundle deal on LG 27MD5KA 27" 5120x2880 14ms HDMI DisplayPort USB-C Thunderbolt Ultra HD IPS LED Monitor
£1,050.66
Diagonal Size: 27in
Response Time: 14ms
Brand: LG
Price Range Ex VAT: 750 - 1000
