LG 27BK550Y 27" 1920x1080 5ms VGA DVI HDMI DisplayPort Monitor
Quicklinx: DN96WS00 Mfr#: 27BK550Y
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£159.54 ex VAT
£191.44 inc VAT
Designed for professionals, this Full HD display with IPS technology minimizes color shifts and provides outstanding picture quality from virtually any viewing angle.
The power module is integrated with the monitor, helping to reduce the amount of power modules in your workspace.
The monitors provide comfortable viewing with versatile screen height/tilt/pivot/swivel adjustments. You can customize the display condition to create a more personal, comfortable workstation. The monitor can be easily assembled without any tools, and is also able to be wall-mounted.
  • Full HD IPS display
  • Integrated power module for organized workspaces
  • Personalized viewing angles and easy assembly
LG 27BK550Y - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Black texture
62.22 cm x 24 cm x 40.16 cm
7.2 kg
Plug and Play, FCC Class B certified, UL, TUV GS, cUL, CB, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, REACH, EPA 7.0
Display Type
Energy Class
Class A
38 kWh
26 W
Diagonal Size
27"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean, UK English
Flicker Safe, Reader Mode, Factory Calibration, 6-axis colour adjustment, Smart Energy Saving technology, Color Calibrated, Mini PC attachable, Super Resolution+
Black texture
62.22 cm x 24 cm x 40.16 cm - with stand
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
1.2 Watt
HDMI , DVI-D , VGA , Headphones , 2 x USB 2.0 downstream , USB 2.0 upstream , DisplayPort , Audio line-in
Mechanical
Tilt Angle
-5/+35
Swivel Angle
355
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), PVC free
1 x DVI cable , 1 x DisplayPort cable , 1 x audio cable , 1 x USB cable
MTBF
70,000 hour(s)
27.4 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 62.2 cm - depth: 5.84 cm - height: 37.15 cm - weight: 5.1 kg , With stand - width: 62.22 cm - depth: 24 cm - height: 40.16 cm - weight: 7.2 kg
Shipping Width
70.7 cm
Shipping Depth
55.6 cm
Shipping Height
18.6 cm
Shipping Weight
10 kg
Diagonal Size: 27in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: LG
Price Range Ex VAT: 150 - 300
