LG 24MP88HV 23.8" 1920 x 1080 5ms DVI HDMI Full HD LED Monitor
Quicklinx: CWT6WS00 Mfr#: 24MP88HV
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15)
18 in stock
£147.01 ex VAT
£176.41 inc VAT
This monitor features an Infinity display that provides a borderless visual experience for 4-side of the display for an all-inclusive view. Smoothness and solidness coexist in the curved structure - the beauty of ArcLine is the icing on the cake.
  • Infinity display
    The Infinity display provides a borderless visual experience for 4-side of the display for an all-inclusive view.
  • ArcLine stand
  • Enjoy outstanding color expression
    The LG IPS monitor provides an accurate color and low-color shift. It delivers realistic color expression.
  • Protect your eyes and view in comfort
    Over time, working, gaming and movie viewing can cause eye strain and fatigue. But, this display features technologies that help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level.
  • Customize your workspace for multitasking
    Screen Split divides the display into multiple sections for different tasks by resizing the windows on the screen. With PIP mode you can work on the main screen while watching a video in a smaller window floating on the screen.
  • Offers improved color vision to color weakness
    Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
LG 24MP88HV - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Silver spray with white back
54.1 cm x 18.62 cm x 41.45 cm
3.2 kg
Plug and Play, FCC Class B certified, TUV, DDC/CI, ERP, EPA 6.0
Display Type
Energy Class
Class A
28 kWh
19 W
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture in picture, split screen, Picture Mode, SUPER Energy Saving Technology, 99% sRGB colour gamut, Flicker Safe, Reader Mode, SIX Axis Control, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Black Stabilizer, My Display Preset, Color Weakness Mode, Mega DFC
54.1 cm x 18.62 cm x 41.45 cm - with stand
3.2 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
VGA , 2 x HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-2/+15
VESA Mounting Interface
75 x 75 mm
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 54.1 cm - depth: 18.62 cm - height: 41.45 cm - weight: 3.2 kg , Without stand - width: 54.1 cm - depth: 4.66 cm - height: 31.33 cm - weight: 2.9 kg
Response Time: 5ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: LG
Price Range Ex VAT: 100 - 150
