Product
LG 24MP58VQ-P 24" 1920x1080 5ms HDMI DVI-D Monitor
Quicklinx: C5MVWS00 Mfr#: 24MP58VQ-P
Marketing description is not available.
  • Full HD IPS display
    IPS (In-Plane Switching) technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
  • On-Screen control
    On-Screen control puts a host of essential settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split and more can now be adjusted with just a few clicks of the mouse.
  • Screen Split
    Customize your monitor layout for multitasking with the latest version of LG Screen Split. Resize and display multiple windows at once, with 14 options including four different picture-in-picture (PIP) choices.
  • Black Stabilizer
    Keep visibility even in dark scenes. LG's Black Stabilizer senses dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark.
  • Reader mode
    Reducing blue light to help lessen eye fatigue, Reader mode provides optimal condition for reading. With just a click of a mouse, you can more comfortably read your monitor screen.
  • Sleek design
    The panel's slim and sleek design is about form meeting function. The reduction of panel depth adds a sharp, clean look to a workspace at the same time frees up space on your desktop.
  • ArcLine stand
    The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
LG 24MP58VQ-P - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
25 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Input Connectors
HDMI, DVI, VGA
55.05 cm x 8.65 cm x 33.21 cm
2.8 kg
Plug and Play, DDC/CI
3 years warranty
Display Type
Energy Class
Class B
36 kWh
25 W
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
SUPER Energy Saving Technology, Flicker Safe, Reader Mode, Multilingual On Screen Display, Black Stabilizer, My Display Preset, Sleek Cut Design
55.05 cm x 8.65 cm x 33.21 cm - without stand
2.8 kg
VGA , HDMI , DVI , Headphones
AC 120/230 V
23 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 55.05 cm - depth: 8.65 cm - height: 33.21 cm - weight: 2.8 kg , With stand - width: 55.05 cm - depth: 18.68 cm - height: 41.9 cm - weight: 3.2 kg
Limited warranty - 3 years
C5MV C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.95
C5MV C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.31
C5MV C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.89
C5MV C2G 2M DVI D M/F DIGITAL VIDEO EXT CBL In Stock £10.82
C5MV C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
C5MV C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.59
C5MV C2G USB to DVI Adapter Up To 2048 x 1152 In Stock £38.98
C5MV C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.65
