LG 24MK600M-B 24" 1920x1080 5ms VGA HDMI IPS LED Monitor
Quicklinx: DRZ3WS00 Mfr#: 24MK600M-B
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
£91.17 ex VAT
£109.40 inc VAT
This streamlined display features a slim bezel on three sides for an immersive visual experience and no distraction from the dazzlingly precise, lifelike image. IPS technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can view the screen at virtually any angle.
LG 24MK600M-B - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
Adaptive-Sync Technology
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2744 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Matte black
48.87 cm x 18.2 cm x 38.67 cm
2.7 kg
FCC Class B certified, TUV, SEMKO, DDC/CI, IEC 62087 Edition 2
Display Type
Energy Class
Class A+
25 kWh
Diagonal Size
24"
Viewable Size
23.8"
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2744 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
4:3 in Wide, Mega Contrast, On-screen Digital Controls, Crosshair Display, Flicker Safe, Reader Mode, Mercury free, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Mega DFC, frameless bezel design
Matte black
48.87 cm x 18.2 cm x 38.67 cm - with stand
2.7 kg
2 x HDMI (HDCP) , VGA , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
Cable holder
1 x HDMI cable - 1.8 m , 1 x VGA cable
Security Slot Type
Kensington security slot
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 48.87 cm - depth: 18.2 cm - height: 38.67 cm - weight: 2.7 kg , Without stand - width: 48.87 cm - depth: 6.68 cm - height: 29.3 cm - weight: 2.3 kg
Shipping Width
56.1 cm
Shipping Depth
36.3 cm
Shipping Height
13.9 cm
Shipping Weight
3.7 kg
LG 24MK600M-B 24 Bundle deal on LG 24MK600M-B 24" 1920x1080 5ms VGA HDMI IPS LED Monitor
£190.34
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: LG
Price Range Ex VAT: 50 - 100
