- LG 24MK430H-B - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 24 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.2744 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Matte black
- 55.5 cm x 18.19 cm x 42.1 cm
- 3.1 kg
- FCC Class B certified, TUV, SEMKO
- Display Type
- Energy Class
- Class A
- 35 kWh
- 24 W
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- AMD FreeSync
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2744 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Mega Dynamic Contrast Ratio, On-screen Digital Controls, Crosshair Display, Flicker Safe, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), My Display Preset, Color Weakness Mode
- Matte black
- 55.5 cm x 18.19 cm x 42.1 cm - with stand
- 3.1 kg
- HDMI , VGA , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 75 x 75 mm
- Included Accessories
- Cable holder
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 30 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 55.5 cm - depth: 18.19 cm - height: 42.1 cm - weight: 3.1 kg , Without stand - width: 55.5 cm - depth: 3.84 cm - height: 33.09 cm - weight: 2.8 kg
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£190.80
