With the clarity of 1080p Full HD, everything looks more detailed than standard HD and a lot more inviting.
With Radeon FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. Radeon FreeSync virtually eliminates screen tearing and stuttering.
Minimize input lag with Dynamic Action Sync so you can catch every single moment in real time.
OnScreen Control is simple and intuitive. You can customize your display options with a few simple clicks.
This monitor gives you the freedom to take it off the desk and hang it on the wall. Liberate your viewing options and save desktop space with this wall-mountable LG monitor.
- LG 24MK400H-B - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (VGA: 60 Hz, HDMI: 75 Hz)
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931)
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 55.5 cm x 18.19 cm x 42.05 cm
- 2.8 kg
- Display Type
- Energy Class
- Class F
- 34 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (CIE 1931)
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Multilingual
- Game mode, Cinema Mode, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode, Mega DFC, Super Resolution+
- Matte black
- 55.5 cm x 18.19 cm x 42.05 cm - with stand
- 2.8 kg
- HDMI , VGA , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- Security Slot Type
- Kensington security slot
- Input Voltage
- 23 W
- Power Consumption SDR (On mode)
- 20.8 kWh/1000h
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 55.5 cm - depth: 18.19 cm - height: 42.05 cm - weight: 2.8 kg , Without stand - width: 55.5 cm - depth: 3.84 cm - height: 33.09 cm - weight: 2.5 kg
- Shipping Width
- 68.8 cm
- Shipping Depth
- 12.4 cm
- Shipping Height
- 39 cm
- Shipping Weight
- 4.1 kg
