LG 24MK400H-B 24" 1920x1080 2ms VGA HDMI LED Monitor
Quicklinx: DRYZWS00 Mfr#: 24MK400H-B
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
26 in stock
£87.74 ex VAT
£105.28 inc VAT
With the clarity of 1080p Full HD, everything looks more detailed than standard HD and a lot more inviting.
With Radeon FreeSync, gamers can experience seamless, fluid movement throughout hi-res, fast-paced games. Radeon FreeSync virtually eliminates screen tearing and stuttering.
Minimize input lag with Dynamic Action Sync so you can catch every single moment in real time.
OnScreen Control is simple and intuitive. You can customize your display options with a few simple clicks.
This monitor gives you the freedom to take it off the desk and hang it on the wall. Liberate your viewing options and save desktop space with this wall-mountable LG monitor.
LG 24MK400H-B - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (VGA: 60 Hz, HDMI: 75 Hz)
Brightness
200 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Matte black
55.5 cm x 18.19 cm x 42.05 cm
2.8 kg
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
24"
Viewable Size
23.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Multilingual
72% (CIE 1931) colour gamut, game mode, Cinema Mode, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode, Mega DFC, Super Resolution+
Matte black
55.5 cm x 18.19 cm x 42.05 cm - with stand
2.8 kg
HDMI , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
Security Slot Type
Kensington security slot
30 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 55.5 cm - depth: 18.19 cm - height: 42.05 cm - weight: 2.8 kg , Without stand - width: 55.5 cm - depth: 3.84 cm - height: 33.09 cm - weight: 2.5 kg
Shipping Width
68.8 cm
Shipping Depth
12.4 cm
Shipping Height
39 cm
Shipping Weight
4.1 kg
LG 24MK400H-B 24 Bundle deal on LG 24MK400H-B 24" 1920x1080 2ms VGA HDMI LED Monitor
£186.91
Diagonal Size: 24in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: LG
Price Range Ex VAT: 50 - 100
