LG 24M47VQ 24" 1920x1080 2ms VGA DVI HDMI LED Monitor
Quicklinx: BNJ4WS00 Mfr#: 24M47VQ
Protect your eyes with Reader Mode
Activate Reader Mode with a simple touch of a hot key to minimize exposure to harmful blue light. Spend as much time as you want working, playing games, or watching movies without straining your eyes. Use the convenient and easy-to-use hot keys for increased satisfaction.
Flicker Safe
Reducing the flicker level to almost zero, Flicker-Safe helps you proetect your eyes from exhausting flickers. Work and entertain as long as you want with the IPS monitor.
Colour Wizard
The Color Wizard feature prevents color-weak people from missing important content by distinguishing certain ranges of colors via the color revision algorithm.
Smart Energy Saving
LG Smart Energy Saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight, has improved. * Conserve energy by adjusting screen brightness.
LG 24M47VQ - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (typical); 2 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Screen Coating
Anti-glare
55.7 cm x 19.7 cm x 43.8 cm
Plug and Play, DDC/CI
Display Type
Energy Class
Class B
37 kWh
25 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
SUPER Energy Saving Technology, 4-screen split, Flicker Safe, Reader Mode
55.7 cm x 19.7 cm x 43.8 cm - with stand
VGA ¦ DVI-D ¦ HDMI ¦ Headphones
28 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 55.7 cm - depth: 19.7 cm - height: 43.8 cm , Without stand - width: 55.7 cm - depth: 6 cm - height: 34.2 cm
