LG 24BK750Y 24" 1920x1080 5ms DVI HDMI DisplayPort Monitor
Quicklinx: DN98WS00 Mfr#: 24BK750Y
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
£181.41 ex VAT
£217.69 inc VAT
Designed for professionals, this Full HD display with IPS technology minimizes color shifts and provides outstanding picture quality from virtually any viewing angle.
  • Full HD IPS display
  • A new sense of immersion with borderless design
    The three-side borderless screen minimizes the bezel so the display blends seamlessly into any workspace. It enhances the sense of immersion and adds aesthetic appeal.
  • Personalized viewing angles and easy assembly
    The monitors provide comfortable viewing with versatile screen height/tilt/pivot/swivel adjustments. You can customize the display condition to create a more personal, comfortable workstation. The monitor can be easily assembled without any tools, and is also able to be wall-mounted.
  • Easy to duplicate and extend screen with daisy chain
    The Daisy Chain lets you connect up to four monitors with duplication and extension functions. This setup creates synergy, allowing efficient resource sharing throughout an organization.
LG 24BK750Y - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Textured black
53.94 cm x 27.61 cm x 52.39 cm
6.2 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, cUL, CB, TUV Ergo, DDC/CI, ISO 9241-307, TCO Displays 6.0, EPA 7.0
Display Type
Energy Class
Class A
29 kWh
20 W
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
HDCP, 72% (CIE 1976) colour gamut, Picture Mode, Flicker Safe, SIX Axis Control, Smart Energy Saving technology, Color Calibrated, Dual Controller, Response Time Control
Textured black
53.94 cm x 27.61 cm x 52.39 cm - with stand
6.2 kg
Audio
Speakers - stereo
Output Power / Channel
1.2 Watt
DisplayPort , DVI-D , HDMI , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+25
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Cable holder
1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
23 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.003 Watt
Dimensions & Weight Details
With stand - width: 53.94 cm - depth: 27.61 cm - height: 52.39 cm - weight: 6.2 kg , Without stand - width: 53.94 cm - depth: 5.87 cm - height: 32.64 cm - weight: 3.4 kg
ENERGY STAR Certified
LG 24BK750Y 24 Bundle deal on LG 24BK750Y 24" 1920x1080 5ms DVI HDMI DisplayPort Monitor
£280.58
Diagonal Size: 24in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Brand: LG
Price Range Ex VAT: 150 - 300
