LG 22MK430H-B 22" 1920x1080 5ms VGA HDMI IPS LED Monitor
Quicklinx: DRZ0WS00 Mfr#: 22MK430H-B
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
£70.17 ex VAT
£84.20 inc VAT
LG 22MK430H-B - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class B
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Matte black
50.96 cm x 18.19 cm x 39.58 cm
2.8 kg
FCC Class B certified, TUV, SEMKO
Display Type
Energy Class
Class B
31 kWh
21 W
Diagonal Size
22"
Viewable Size
21.5"
AMD FreeSync
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Mega Dynamic Contrast Ratio, On-screen Digital Controls, Crosshair Display, Flicker Safe, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), My Display Preset, Color Weakness Mode
Matte black
50.96 cm x 18.19 cm x 39.58 cm - with stand
2.8 kg
HDMI , VGA , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
Cable holder
1 x HDMI cable - 1.8 m , 1 x VGA cable
Security Slot Type
Kensington security slot
29 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 50.96 cm - depth: 18.19 cm - height: 39.58 cm - weight: 2.8 kg , Without stand - width: 50.96 cm - depth: 3.85 cm - height: 30.57 cm - weight: 2.5 kg
LG 22MK430H-B 22 Bundle deal on LG 22MK430H-B 22" 1920x1080 5ms VGA HDMI IPS LED Monitor
£169.34
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: LG
Price Range Ex VAT: 50 - 100
