LG 22MK400H-B 22" 1920x1080 5ms VGA HDMI IPS LED Monitor
Quicklinx: DRYXWS00 Mfr#: 22MK400H-B
None in stock
Full HD resolution with IPS delivers brilliant images that pop with vibrant detail from any viewing angle. AMD FreeSync Technology and a dynamic refresh rate virtually eliminates screen tearing and stuttering to bring you seamless, fluid movement during high-res, fast-paced games.
Dynamic Action Sync mode allows you to instantly react to your opponents and attack them without any display lag. It synchronizes your senses with real-time scenes in fast-paced games by minimizing input lag.
Black Stabilizer gives you full visual clarity, even in games where you spend a lot of time in the dark. It synchronizes and brightens the darkest areas, so that you can find enemies hiding in the shadows and shoot first.
  • High definition with accurate color
  • Clearer, smoother image
  • React faster to the action
  • Enemies have nowhere to hide
  • Easier user interface
    OnScreen Control is simple and intuitive. You can customize your display options with a few simple clicks.
  • Convenient and flexible
    Mount the monitor to suit your work or entertainment set up.
LG 22MK400H-B - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2537 mm
Brightness
250 cd/m²
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
55.6 cm x 18.2 cm x 42.1 cm
3.08 kg
Plug and Play, FCC Class B certified, UL, TUV, VCCI, cUL, DDC/CI, ERP
1-year warranty
Display Type
Energy Class
Class A
29 kWh
20 W
Diagonal Size
22"
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2537 mm
Brightness
250 cd/m²
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Digital Fine Contrast (DFC), 72% (CIE 1931) colour gamut, OSD lock, Crosshair Display, Flicker Safe, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, Colour Temperature Selection, Super Resolution+
55.6 cm x 18.2 cm x 42.1 cm - with stand
3.08 kg
HDMI (HDCP) , VGA (HD-15) , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
HDMI cable
Security Slot Type
Kensington security slot
30 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 55.6 cm - depth: 18.2 cm - height: 42.1 cm - weight: 3.08 kg , Without stand - width: 55.6 cm - depth: 3.81 cm - height: 33.5 cm - weight: 2.81 kg
Shipping Width
68.8 cm
Shipping Depth
12.4 cm
Shipping Height
39.1 cm
Shipping Weight
4.22 kg
Limited warranty - 1 year
