LG 22MK400A 22" 1920x1080 5ms VGA LED Monitor
Quicklinx: DVJHWS00 Mfr#: 22MK400A-B
Full HD Picture Quality
With clarify of 1080p Full HD, everything looks more detailed than standard HD and a lot more inviting on the LG 22MK400A.
OnScreen Control
LG 22MK400A OnScreen Control is simple and intuitive. You can customize your display options with a few simple clicks.
Reader Mode
Reducing blue light to help lessen eye fatigue, Reader Mode provides optimal condition for reading. With easy joystick control, you can more comfortably read your monitor screen.
Offers Stable Image
Reducing the flicker level to almost zero, Flicker-Safe helps you protect your eyes from exhausting flickers.
Dynamic Action Sync
Minimize input lag with Dynamic Action Sync so you can catch every single moment in real-time.
Black Stabilizer
You can avoid snipers hiding in the darkest places and quickly escape situations when the flash explodes.
Wall Mountable
This LG 22MK400A monitor gives you the freedom to take it off the desk and hang it on the wall. Liberate your viewing options and save desktop space with this wall-mountable LG monitor.
  • Experience stunning Full HD
    With clarify of 1080p Full HD, everything looks more detailed than standard HD and a lot more inviting.
  • Protect eyes with Reader Mode
  • Flicker Safe
  • Dynamic Action Sync
  • Black stabilizer
  • OnScreen Control
LG 22MK400A-B - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Adaptive-Sync Technology
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
51 cm x 18.2 cm x 36 cm
2.4 kg
Display Type
Diagonal Size
22"
Viewable Size
21.5"
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
600:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
72% NTSC colour gamut, Crosshair Display, Flicker Safe, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), FreeSync Technology, Color Weakness Mode, Mega DFC
51 cm x 18.2 cm x 36 cm - with stand
2.4 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
75 x 75 mm
Security Slot Type
Kensington security slot
19.7 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 51 cm - depth: 18.2 cm - height: 36 cm - weight: 2.4 kg , Without stand - width: 51 cm - depth: 3.8 cm - height: 30.6 cm - weight: 2.1 kg
