Protect your eyes with Reader Mode
Activate Reader Mode with a simple touch of a hot key to minimize exposure to harmful blue light. Spend as much time as you want working, playing games, or watching movies without straining your eyes. Use the convenient and easy-to-use hot keys for increased satisfaction.
Flicker Safe
Reducing the flicker level to almost zero, Flicker-Safe helps you proetect your eyes from exhausting flickers. Work and entertain as long as you want with the IPS monitor.
Colour Wizard
The Color Wizard feature prevents color-weak people from missing important content by distinguishing certain ranges of colors via the color revision algorithm.
Smart Energy Saving
LG Smart Energy Saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight, has improved. * Conserve energy by adjusting screen brightness
- LG 22M47VQ - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class B
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Screen Coating
- Anti-glare
- 51 cm x 19.7 cm x 40.9 cm
- Plug and Play, DDC/CI
- Display Type
- Energy Class
- Class B
- 34 kWh
- Diagonal Size
- 22"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- SUPER Energy Saving Technology, 4-screen split, Flicker Safe, Reader Mode
- 51 cm x 19.7 cm x 40.9 cm - with stand
- VGA , DVI-D , HDMI , Headphones
- 23 W
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 51 cm - depth: 19.7 cm - height: 40.9 cm , Without stand - width: 51 cm - depth: 6.8 cm - height: 31.4 cm
Accessories (4)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.78 |
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.06 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
Other bundles (2)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black | In Stock | £14.57 |
