LG 22BK55WY 22" 1680x1020 5ms VGA DVI LCD Monitor
Quicklinx: DN94WS00 Mfr#: 22BK55WY
Diagonal Size: 22in
Max Resolution: 1680 x 1050
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, VGA (HD-15)
£102.66 ex VAT
£123.19 inc VAT
The IPS displays clear and accurate colors from all angles for advanced work, making the panel suitable for professionals. Also, IPS picture quality allows you to create outstanding output.
The monitors provide comfortable viewing with versatile screen height/tilt/pivot/swivel adjustments. You can customize the display for a personal, comfortable workstation depending on various contents or office tools.
  • Full HD IPS display
  • Ergonomics for perfect working conditions
  • Advanced tech design
    The advanced design can be installed quickly and easily without the need for any tools. Also, the wall mount gives you the freedom to take it off the desk and hang it on a wall.
  • Built-in power for orderly workspaces
    A power module is attached to the monitor from behind for built-in power, eliminating a mess of cables. Ultimately, an office using a number of PCs could be more pleasant by saving each desktop space.
LG 22BK55WY - LED monitor - 22"
LED-backlit LCD monitor - 22"
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.2821 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Anthracite dark
50.6 cm x 23.9 cm x 37.9 cm
4.7 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
Plug and Play, CSA, UL, TUV GS, NEMKO, SEMKO, EN 61000-3-3, EN55024, TUV Ergo, DDC/CI, RoHS, Directive 2006/95/CE, EN 60950-1:2006, EN61000-3-2:2006, EMC 2004/108/EC, EN55022:2006 Class B, DIN ISO 9241-307, EPA 7.0
3-year warranty
Display Type
Diagonal Size
22"
Viewable Size
22"
Built-in Devices
USB 2.0 hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.2821 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Mega Dynamic Contrast Ratio, Multiscan Support, Flicker Safe, Reader Mode, Mercury free, Smart Energy Saving technology, Color Calibrated, One Click Stand, Mini PC attachable
Anthracite dark
50.6 cm x 23.9 cm x 37.9 cm - with stand
4.7 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
DVI-D , VGA , 2 x USB 2.0 , Audio line-in , Headphones , DisplayPort
Mechanical
Tilt Angle
-5/+35
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x audio cable - 1.8 m , 1 x USB cable , 1 x DVI cable - 1.8 m
Backlight Life
50,000 hours
MTBF
70,000 hour(s)
15.8 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0 Watt
Dimensions & Weight Details
With stand - width: 50.6 cm - depth: 23.9 cm - height: 37.9 cm - weight: 4.7 kg , Without stand - width: 50.6 cm - depth: 5.8 cm - height: 33.9 cm - weight: 3.5 kg
ENERGY STAR Certified
TCO Certified
- backlight - 3 years
LG 22BK55WY 22 Bundle deal on LG 22BK55WY 22" 1680x1020 5ms VGA DVI LCD Monitor
£201.83
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: LG
Price Range Ex VAT: 100 - 150
