The Lexmark X925de color MFP delivers affordable A3 and color functionality for your busy workgroup through easy-to-use features, productivity solutions and a compact design.
The extra large 10.2-inch color touch screen allows you to operate your printer with ease and confidence through smart and intuitive navigation, easy access to workflow solutions and shortcuts, and the ability to preview your documents and print jobs at the device.
Intuitive Colour Touch Screen
The extra large 10 inch class (25 cm) colour touch screen allows you to operate your printer with ease and confidence through smart and intuitive navigation, easy access to workflow solutions and shortcuts, and the ability to preview your documents and print jobs at the device. -
Recirculating Automatic Document Feeder (RADF)
Save time by scanning both sides of your document with robust colour-scanning capabilities and an input capacity of up to 100 pages. -
Affordable A3 Colour Printing
Vibrant, professional-quality output on a wide variety of media for more colour printing in-house. Supports media up to 11.7 x 48 inches. -
Lexmark Solutions
Reduce unnecessary printing and simplify work processes through solution applications preloaded on your device. Choose additional Lexmark solutions to fit your unique workflow needs. -
Business Productivity
Scan to multiple destinations, including scan to email, scan to FTP, scan to fax, scan to network and more. -
Advanced Security
Protect your device, data and network with innovative security controls, like authentication and authorisation, and a hard disk with disk wiping and encryption.
- Lexmark X925de - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (colour)
- Monthly Duty Cycle (max)
- 200000 impressions
- Recommended Monthly Volume
- 5000 - 10000 pages
- Max Copying Speed
- Up to 31 ppm (mono) / up to 31 ppm (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 600 dpi
- Display
- 10.2"
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, banner
- Standard Media Capacity
- 450 sheets
- Max Media Capacity
- 2100 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Scan to e-mail, scan to network
- 67.2 cm x 66.8 cm x 77.1 cm
- 79.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- LED - colour
- Display Diagonal Size
- 10.2"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 512 MB 512 MB
- Max Supported Memory
- 1536 MB 1.5 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PPDS, XPS, PDF 1.6
- Image Enhancement Technology
- 1200 IQ
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 11 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Max Media Size
- A3/Ledger
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 450 sheets
- 2100 sheets
- 50 sheets
- 250 sheets
- Input tray - 150 sheets , Bypass tray - 50 sheets , Output tray - 250 sheets , ADF - 100 sheets , Input tray - 250 sheets
- Speed Details
- Printing: up to 31 ppm (A4) - B/W , Printing: up to 31 ppm (A4) - colour , Printing: up to 26 spm (A4) - B/W duplex , Copying: up to 31 ppm (A4) - B/W , Copying: up to 31 ppm (A4) - colour , Copying: up to 13 spm (A4) - B/W duplex , Scanning: up to 33 ppm (A4) - B/W , Scanning: up to 32 ppm (Letter A) - B/W , Scanning: up to 33 ppm (A4) - colour , Scanning: up to 32 ppm (Letter A) - colour , Scanning: up to 12 spm (A4) - B/W , Scanning: up to 12 spm (Letter A) - B/W , Scanning: up to 12 spm (A4) - colour , Scanning: up to 12 spm (Letter A) - colour
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Network Protocols
- TCP/IP, AppleTalk, IPP, LPR/LPD, SNMP, HTTP, HTTPS, IPv4, IPv6, Bonjour, FTP, DHCP, BOOTP, RARP
- SSL, LEAP, TLS, IPsec, 802.1x, ARP
- Operating System Support
- MS Windows XP, Apple Mac OS X, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, IBM AIX 5.2, Red Hat Enterprise Linux WS 4.0, MS Windows 7, Red Hat Enterprise Linux WS 5.0, SuSE Linux Enterprise Server 10, SuSE Linux Enterprise Server 11, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, openSUSE 11.0, openSUSE 11.1, Debian GNU/Linux 5.0, Red Flag Linux Desktop 6.0, Ubuntu Linux 9.04, HP-UX 11.11, HP-UX 11.23, HP-UX 11.31, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, IBM AIX 5.3, SunSoft Solaris x86 10, IBM AIX 6.1, Linux Linpus Desktop 9.6, Ubuntu Linux 9.10, Ubuntu Linux 10.04, MS Windows Server 2008 R2, Fedora 12, Fedora 13
- First Copy Out Time B/W
- 17 sec
- First Copy Out Time Colour
- 17 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 8500 pages , 1 x toner cartridge (cyan) - up to 7500 pages , 1 x toner cartridge (magenta) - up to 7500 pages , 1 x toner cartridge (yellow) - up to 7500 pages
- FCC Class A certified, TUV GS, CISPR 22 Class A, BSMI CNS 13438 Class A, SABS, VCCI Class A ITE, EN55024, EN55022 Class A, IEC 60320-1, AS/NZS 60950-1, CCC, PSB, MIC, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07, TUV Rh, BSMI CNS 13438, A-Tick, FDA, UL-AR, GOST-R, BSMI Class A, CAN/CSA C22.2 No. 60950-1-07
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site - response time: next business day
- 67.2 cm
- 66.8 cm
- 77.1 cm
- 79.3 kg
- Shipping Width
- 78.9 cm
- Shipping Depth
- 79.8 cm
- Shipping Height
- 118.2 cm
- Shipping Weight
- 110 kg
- Sound Emission
- 39 dBA (idle) / 53 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80%
