The Lexmark MS822de combines a first page as fast as 4.5 seconds and impressive output speed with a 4.3-inch touch screen offering productivity-enhancing apps.
Engineered to last
Steel frames and a robust paper feeding system that reliably handles diverse media types and sizes support heavy-duty use and a long life in even the harshest environments. Plus, innovations in part replacement and accessibility help you resolve problems quickly. -
Fast start + enduring performance
A first page as fast as 4.5 seconds sets the stage for printing and copying up to 55 [52] ppm. And support for large workloads is built in, with recommended monthly page volume as high as 350,000 pages. -
Ready to work
With access to input capacity of up to 4400 sheets, replacement toner cartridges that go as high as 15,000 pages, long-life imaging unit and a fuser that may never need replacement, you'll spend more time printing. -
Meet the future
A combination of 1-GHz dual-core processor and 1 GB of memory (upgradeable to 5 GB) has the power to handle demanding tasks right now while providing a secure, upgradeable framework for future advances in product functionality. And Lexmark's most energy-efficient large-workgroup monochrome products ever are rated EPEAT Silver and ENERGY STAR (2.0) certified. -
Interact with ease
With new front power button and USB port, 4.3-inch [10-cm] e-Task touch screen to monitor and configure system settings and single-door access to parts and supplies, it's easier than ever to get things done. Convenient front access to the paper path means you'll virtually never have to access the back of the device, allowing placement in or on cabinets. And ADA-compliant trays have push-button sliders and open with one hand, requiring low force and no twisting. -
Full-spectrum security
Lexmark's comprehensive approach to product security is a design and engineering mandate across our entire product portfolio. Our security features help keep your information safe-in the document, on the device, over the network and at all points in between. That's why Keypoint Intelligence - Buyers Lab honored Lexmark with a prestigious BLI PaceSetter award for Document Imaging Security. And this Lexmark product enables you to be GDPR ready.
- Lexmark MS822de - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 25.6 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 52 ppm - B/W (ISO/IEC 24734) , Up to 32 spm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution Class (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- 2400 IQ
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Preview Screen Size
- 4.3"
- Processor
- 1000 MHz
- RAM Installed (Max)
- 1 GB (5 GB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, XPS, PDF 1.7
- Barcodes
- OCR-A, OCR-B
- Media Type
- Envelopes, transparencies, labels, plain paper, card stock
- Total Media Capacity
- 650 sheets
- Media Handling
- 100-sheet multipurpose tray, 550-sheet input tray
- Monthly Duty Cycle (max)
- 250000 pages
- Recommended Monthly Volume
- 3000 - 50000 pages
- Networking
- Print server
- Printer Features
- Internal card slot
- System Requirements
- Microsoft Windows 7, SunSoft Solaris x86 10, SuSE Linux Enterprise Server 11, Apple MacOS X 10.6, Microsoft Windows 7 64-bit Edition, SuSE Linux Enterprise Server 10, Apple MacOS X 10.5, IBM AIX 6.1, Apple MacOS X Lion 10.7, Windows 8, IBM AIX 7.1, SunSoft Solaris x86 11, Red Hat Enterprise Linux WS 6, Windows 8 64-bit Edition, Apple MacOS X 10.8, Debian GNU/Linux 7.0, Windows 8.1 64-bit Edition, Windows 8.1, Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10, SuSE Linux Enterprise Server 12, Apple MacOS X 10.11, Debian GNU/Linux 8.0, Red Hat Enterprise Linux WS 7, Ubuntu 16.04 LTS, SUSE Linux 13.2, Apple macOS 10.12, Linux Fedora 23, Linux Fedora 24, openSUSE 42.3
- 1-year warranty
- 42.8 cm x 51 cm x 44.1 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Touch screen
- 4.3"
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- 2400 IQ
- PostScript Support
- Standard
- First Print Out Time B/W
- 4.5 sec
- Fonts Included
- 158 x scalable PostScript , 2 x bitmapped PCL , 84 x scalable PCL , 39 x scalable PPDS , 5 x bitmapped PPDS
- Barcodes
- OCR-A, OCR-B
- Printer Features
- Media Handling
- Processor
- 1000 MHz
RAM
- 1 GB / 5 GB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 650 sheets
- Media Feeders
- Multi-purpose tray: 1 - 100 sheets , Input tray: 1 - 550 sheets weight: 60 g/m² - 176 g/m² , Output tray: 1 - 550 sheets
- Max Media Capacity
- 4400 sheets
- Output Trays Capacity
- 550 sheets
Duty Cycle
- 250000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, IPP 1.0, IPP 1.1, IPP 2.0
- SSL, LEAP, TLS, 802.1x, TTLS, PEAP, MD5, EAP-MSCHAPv2
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) , 1 x imaging unit - up to 150000 pages at 5% coverage
- FCC Class B certified, C-Tick, GS, NOM, ICES-003 Class B, CCC, DOC, SII, UL 60950-1, BSMI Class B, KCC, IEC 60825-1, FDA, UL-AR, GOST-R, EN 60825-1, KC, CECP, CEL, VCCI Class B, Directive 1275/2008/EC, ECMA-370, EFTA, TER, ISO 532B, TED, IEC/EN 60950-1, CAN/CSA-C22.2 No. 60950-1
- Power Device
- Power supply - internal
- 670 Watt
- Power Consumption Stand by
- 39 Watt
- Power Consumption Sleep
- 1.4 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year - on-site - response time: next business day
- 10 °C
- 32 °C
- 8 - 80%
- Sound Emission (Idle)
- 14 dBA
- Sound Emission (Operating)
- 57 dBA
- 42.8 cm
- 51 cm
- 44.1 cm
- 25.6 kg
- Width (Shipping)
- 55 cm
- Depth (Shipping)
- 65 cm
- Height (Shipping)
- 56.5 cm
- Weight (Shipping)
- 30.6 kg
