Lexmark MC2425adw Colour Laser Multifunction Printer
Quicklinx: F8GNWS00 Mfr#: 42CC443
16 in stock
£192.39 ex VAT
£230.86 inc VAT
The Lexmark MC2425adw packs reliable, productive and secure color multifunction performance into a small-footprint package with output up to 25 pages per minute.
  • 4-year guarantee upon registration
    For an added level of peace of mind, you can benefit from 4-year guarantee coverage upon registration.
  • Engineered to perform - and last
    Driven by a 1.2GHz quad-core processor, the MC2425adw prints up to 23 pages per minute and can scan up to 47 images per minute. With its steel frame, long-life imaging system, ease of upgrades and robust paper feeding system, it's ready for lasting performance in any environment.
  • Interact with ease
    With its small footprint, the MC2425adw is easy to find a place for. And the new front-panel power button and direct-print USB port, 2.4-inch colour LCD with keypad and secure browser-based device management make it easy to interact with.
  • Colour that only looks expensive
    Thanks to PANTONE calibration, embedded colour sample pages and Lexmark colour Replacement, you'll get accurate, professional colour in-house. And you'll save toner with included tools that let you choose when and how much colour to print, including mono-only print drivers, user-based colour print permissions and quotas, global colour density control, object-specific colour Saver, proof before printing and more.
  • Classic connections, wireless convenience
    Beyond included USB and gigabit ethernet, this device lets you connect wirelessly via built-in Wi-Fi, as well as AirPrint, Google Cloud Print, and Mopria on any network with existing Wi-Fi access. And with Lexmark Mobile Print, printing's as easy as hitting print, choosing your printer and picking up your job.
  • Energy efficiency
    Make every watt count with energy management features that reduce power consumption whether the device is active or in sleep mode. Lower fusing temperature, automatic management of processor cores based on workload, and standard two-sided printing all help it achieve EPEAT Silver rating and ENERGY STAR (2.0) certification. That benefits the planet and your budget.
  • Full-spectrum security
    Lexmark's comprehensive approach to product security is a design and engineering mandate across our entire product portfolio. Our security features help keep your information safe - in the document, on the device, over the network and at all points in between. That's why Keypoint Intelligence - Buyers Lab honoured Lexmark with a prestigious BLI PaceSetter award for Document Imaging Security. And this Lexmark product enables you to be GDPR ready.
Lexmark MC2425adw - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
75000 pages
Recommended Monthly Volume
800 - 6500 pages
Max Copying Speed
Up to 23 ppm (mono) / up to 23 ppm (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 600 dpi (600 x 600 dpi color)
Display
2.4"
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, card stock
Standard Media Capacity
250 sheets
Max Media Capacity
900 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB 2.0 host
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to FTP, scan to USB host
44.2 cm x 55.6 cm x 46.2 cm
26.8 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
4-year warranty with product registration
Printer Fonts
Bitmapped PCL x 2 , Scalable PostScript x 158 , Scalable PCL x 84 , Bitmapped PPDS x 5 , Scalable PPDS x 39
Fax Type
Plain paper
Printing Technology
Laser - colour
75000 pages
800 - 6500 pages
Display Diagonal Size
2.4"
Display Colour Support
AirPrint Enabled
Standard Memory
1 GB
Max Supported Memory
1 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PPDS, PDF 1.7, XPS
Image Enhancement Technology
4800CQ
Automatic Duplexing
First Print Out Time B/W
11.7 sec
First Print Out Time Colour
11.7 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Oficio (216 x 343 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
250 sheets
Max Media Capacity
900 sheets
1 sheet
150 sheets
Input tray - 250 sheets weight: 90.3 g/m² - 105 g/m² , Bypass tray - 1 sheet , Output tray - 150 sheets , RADF - 50 sheets
Speed Details
Printing: up to 23 ppm (A4) - B/W , Printing: up to 23 ppm (A4) - colour , Printing: up to 12 spm (A4) - B/W duplex , Printing: up to 12 spm (A4) - colour duplex , Copying: up to 23 ppm (A4) - B/W , Copying: up to 23 ppm (A4) - colour , Copying: up to 12 spm (A4) - B/W duplex , Copying: up to 12 spm (A4) - colour duplex , Scanning: up to 21 spm (A4) - B/W duplex , Scanning: up to 23 spm (Letter A) - B/W duplex , Scanning: up to 13 spm (A4) - colour duplex , Scanning: up to 14 spm (Letter A) - colour duplex , Scanning: up to 47 spm (A4) - B/W , Scanning: up to 50 spm (Letter A) - B/W , Scanning: up to 30 spm (A4) - colour , Scanning: up to 32 spm (Letter A) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
Operating System Support
Novell NetWare 6, SuSE Linux Enterprise Server 10, SuSE Linux Enterprise Server 11, Novell NetWare 5.1, Novell NetWare 6.5, SunSoft Solaris x86 10, IBM AIX 6.1, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Red Hat Enterprise Linux WS 6.0, IBM AIX 7.1, Apple Mac OS X 10.8, SunSoft Solaris x86 11, SunSoft Solaris SPARC Platform Edition 10, SunSoft Solaris SPARC Platform Edition 11, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Debian Linux 7.0, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10, Apple Mac OS X 10.11, openSUSE 13.2, Novell Open Enterprise Server 2, Debian Linux 8.0, SuSE Linux Enterprise Server 12, Novell Open Enterprise Server 11, Red Hat Enterprise Linux WS 7.0, macOS 10.12, Fedora Linux 23, Fedora Linux 24, openSUSE 42.3, Ubuntu Linux 16.04 LTS
425 Watt
Power Consumption Standby
38.5 Watt
Power Consumption Sleep
2.2 Watt
First Copy Out Time B/W
12.5 sec
First Copy Out Time Colour
13 sec
Consumables Included
1 x Cartridge (black) - up to 1400 pages ISO/IEC 19798 , 1 x Cartridge (cyan) - up to 750 pages ISO/IEC 19798 , 1 x Cartridge (magenta) - up to 750 pages ISO/IEC 19798 , 1 x Cartridge (yellow) - up to 750 pages ISO/IEC 19798 , 1 x photoconductor unit , 4 x developer
FCC Class B certified, C-Tick, cUL, GS, CB, ICES-003 Class B, CCC, DOC, SII, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI Class B, KCC, IEC 60825-1, FDA, UL-AR, GOST-R, EN 60825-1, KC, CECP, CEL, VCCI Class B, ECMA-370, EFTA, TER, MET, ISO 532B, CAN/CSA-C22.2 No. 60950-1, RAL-UZ 171
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 4 Years
44.2 cm
55.6 cm
46.2 cm
26.8 kg
Shipping Width
55.8 cm
Shipping Depth
59.4 cm
Shipping Height
57 cm
Shipping Weight
30.5 kg
Sound Emission
54 dBA (operating)
16 °C
32 °C
8 - 80%
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: Lexmark
Price Range Ex VAT: 150 - 300
