Work fast and run economically with the MB2546adwe, the fax-equipped high speed multifunction product with long-life components and standard Wi-Fi.
4-year guarantee upon registration
For an added level of peace of mind, you can benefit from 4-year guarantee coverage upon registration. -
Ready when you are
Robust and reliable, Lexmark multifunction products are built to work anywhere, from showroom to warehouse, with few interventions. Keep going with long-life components, replacement cartridge yields of up to 10,000 pages and a maximum input capacity of 2,000 pages. -
Full-spectrum security
Lexmark's comprehensive approach to product security is a design and engineering mandate across our entire product portfolio. Our security features help to keep your information safe - in the document, on the device, over the network and at all points in between. That's why Keypoint Intelligence - Buyers Lab honoured Lexmark with a prestigious BLI PaceSetter award for Document Imaging Security. And this Lexmark product enables you to be GDPR ready. -
Get more done
When performance meets simplicity, you get more done. The intuitive 10 cm tablet-like colour touch screen makes your tasks easy, and it's the gateway to built-in productivity apps that save time and improve efficiency. With 44-pages-per-minute printing, and a skilled scanner that can accurately capture up to 42 images per minute, even with mixed originals, you'll get what you need in a flash. -
Wireless convenience
USB and gigabit ethernet connections are just the start. Standard Wi-Fi means convenient and secure connectivity, whilst the Lexmark Mobile Assistant app allows fast and easy setup directly from your mobile device. -
Dual-core power
A 1 GHz dual-core processor with 1 GB of standard memory gives you the power to do a combination of faxing, printing, copying and scanning for maximum productivity. And you can be confident that your complex file with images, charts and small print will look just as the way that you designed it. -
Energy efficiency
Make every watt count with energy management features that reduce power consumption, whether the printer is active or in sleep mode. Lower fusing temperature and automatic management of processor cores based on workload help to meet rigorous ENERGY STAR 2.0 requirements. That benefits the planet and your budget.
- Lexmark MB2546adwe - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 120000 pages
- Recommended Monthly Volume
- 2000 - 15000 pages
- Max Copying Speed
- Up to 44 ppm
- Max Printing Speed
- Up to 44 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Printing Resolution Class
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 600 dpi (600 x 600 dpi color)
- Display
- 4.3"
- Original Size
- 215.9 x 355.6 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, card stock
- Standard Media Capacity
- 350 sheets
- Max Media Capacity
- 2000 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB 2.0 host
- Office Machine Features
- Scan to e-mail, scan to network, scan to FTP, scan to USB host, internal card slot
- 48.9 cm x 42.95 cm x 47.7 cm
- 20.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- 4-year warranty with product registration
- Printer Fonts
- Bitmapped PCL x 2 , Scalable PCL x 84 , Scalable PostScript x 91 , Bitmapped PPDS x 5 , Scalable PPDS x 39
- Fax Type
- Plain paper
- Laser - monochrome
- 120000 pages
- Display Diagonal Size
- 4.3"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- Standard Memory
- 1 GB
- Max Supported Memory
- 1 GB
Copying
- Max Copying Speed
- Up to 44 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Up to 44 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PPDS, PDF 1.7, XPS
- Image Enhancement Technology
- 1200 IQ, 2400 IQ
- First Print Out Time B/W
- 6 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Max Original Size
- 215.9 x 355.6 mm
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- 350 sheets
- 2000 sheets
- 100 sheets
- 150 sheets
- Multi-purpose tray - 100 sheets , Input tray - 250 sheets weight: 60 g/m² - 120 g/m² , RADF - 50 sheets , Output tray - 150 sheets
- Speed Details
- Printing: up to 44 ppm (A4) - B/W , Printing: up to 22 spm (A4) - B/W duplex , Copying: up to 44 ppm (A4) - B/W , Copying: up to 23 spm (A4) - B/W duplex , Scanning: up to 42 spm (A4) - B/W , Scanning: up to 45 spm (Letter A) - B/W , Scanning: up to 20 spm (A4) - colour , Scanning: up to 22 spm (Letter A) - colour , Scanning: up to 20 spm (A4/Letter A) - B/W duplex , Scanning: up to 10.5 spm (A4/Letter A) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
- SSL, LEAP, TLS, IPsec, 802.1x, ARP, TTLS, PEAP, MD5, MS-CHAPv2, SNMP 3
- Operating System Support
- Novell NetWare 6, SuSE Linux Enterprise Server 10, SuSE Linux Enterprise Server 11, Novell NetWare 5.1, Novell NetWare 6.5, SunSoft Solaris x86 10, IBM AIX 6.1, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Red Hat Enterprise Linux WS 6.0, IBM AIX 7.1, Apple Mac OS X 10.8, SunSoft Solaris x86 11, SunSoft Solaris SPARC Platform Edition 10, SunSoft Solaris SPARC Platform Edition 11, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Debian Linux 7.0, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10, Apple Mac OS X 10.11, openSUSE 13.2, Novell Open Enterprise Server 2, Debian Linux 8.0, SuSE Linux Enterprise Server 12, Novell Open Enterprise Server 11, Red Hat Enterprise Linux WS 7.0, macOS 10.12, Fedora Linux 23, Fedora Linux 24, macOS 10.13, openSUSE 42.3, Ubuntu Linux 16.04 LTS
- Software Included
- Drivers & Utilities
- 620 Watt
- Power Consumption Standby
- 14.5 Watt
- Power Consumption Sleep
- 2.6 Watt
- First Copy Out Time B/W
- 6 sec
- Consumables Included
- 1 x Cartridge (black) - up to 3000 pages ISO/IEC 19752 , 1 x imaging unit - up to 60000 pages at 5% coverage
- FCC Class B certified, C-Tick, cUL, GS, NOM, CB, ICES-003 Class B, CCC, DOC, SII, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI Class B, KCC, IEC 60825-1, FDA, UL-AR, GOST-R, EN 60825-1, KC, CECP, CEL, VCCI Class B, ECMA-370, EFTA, TER, MET, ISO 532B, TED, CAN/CSA-C22.2 No. 60950-1
- ENERGY STAR Certified
- Limited warranty - 4 Years
- 48.9 cm
- 42.95 cm
- 47.7 cm
- 20.6 kg
- Shipping Width
- 51.1 cm
- Shipping Depth
- 57.6 cm
- Shipping Height
- 61.4 cm
- Shipping Weight
- 23.72 kg
- Sound Emission
- 14 dBA (idle) / 56 dBA (operating)
- 10 °C
- 32 °C
- 8 - 80%
