The Lexmark CX827de workgroup color MFP prints up to 50 pages per minute and has business-class features like pre-installed software solutions and PANTONE -calibrated color.
4 year guarantee? upon registration?
For an added level of peace of mind, you can benefit from 4-year guarantee coverage? upon registration?. -
Production-class performance
A 1.33GHz quad core processor with 2GB of standard memory helps the CX827de handle complex jobs, while print speeds of up to 50 pages per minute allow users in high-volume print environments to get fast colour output. Even large color print jobs complete quickly so users are more productive. -
Professional colour
Professional color features include ultra-sharp 4800 Color Quality, PANTONE calibration and spot color replacement for repeatable color accuracy even with critical corporate identity elements. -
Solutions flexibility
Lexmark's Embedded Solutions Framework lets you run software solutions to meet the needs of your industry. Several solutions are included, and more can be added. -
Advanced media handling
Expand your output capabilities with standard input capacity of up to 650 pages (expandable to 4,500), an optional in-line staple finisher, and the broadest range of media weights possible-from tissue-thin paper to thick card stock. -
Multi-touchscreen
The 10.9 cm e-Task colour touch screen features an ultra-smooth surface that can be activated by almost anything, including pens, fingertips or nails-without pressure or direct skin contact. -
Top-tier scanning
It starts with 1200 dpi CCD-based scan quality for colour and information accuracy, then adds automatic size sensing and ultrasonic multi-feed detection to ensure that every page intended for archiving or integration into your digital workflow is successfully scanned.
- Lexmark CX827de - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 200000 pages
- Recommended Monthly Volume
- 2500 - 25000 pages
- Max Copying Speed
- Up to 50 ppm (mono) / up to 50 ppm (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 600 dpi
- Display
- 7"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 150 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, card stock
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 4500 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to network, scan to FTP
- 76.3 cm x 58.8 cm x 55.9 cm
- 82.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- 4 years warranty
- Fax Type
- Plain paper
- Laser - colour
- 200000 pages
- Display Diagonal Size
- 7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 2 GB
- Max Supported Memory
- 4 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PPDS, PDF 1.7, XPS
- Image Enhancement Technology
- 4800CQ
- First Print Out Time B/W
- 7 sec
- First Print Out Time Colour
- 7 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 1200 x 600 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Fax Machine Features
- Colour faxing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 150 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 176 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), US No 9 (98.6 x 225.6 mm)
- 650 sheets
- 4500 sheets
- 100 sheets
- 300 sheets
- Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 176 g/m² , Input tray - 550 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 176 g/m² , ADF - 150 sheets , Output tray - 300 sheets
- Speed Details
- Printing: up to 50 ppm (A4) - B/W , Printing: up to 50 ppm (A4) - colour , Printing: up to 50 ppm (A4) - B/W duplex , Copying: up to 50 ppm (A4) - B/W , Copying: up to 50 ppm (A4) - colour , Scanning: up to 57 spm (A4) - B/W , Scanning: up to 57 spm (A4) - colour , Scanning: up to 114 spm (A4) - B/W duplex , Scanning: up to 120 spm (Letter A) - B/W duplex , Scanning: up to 114 spm (A4) - colour duplex , Scanning: up to 120 spm (Letter A) - colour duplex , Scanning: up to 60 spm (Letter A) - B/W , Scanning: up to 60 spm (Letter A) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 4 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, Apple Bonjour, TLS, ARP
- Operating System Support
- MS Windows XP, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Vista (64-bit versions), Sun Solaris 10, MS Windows Server 2008, Novell NetWare 6.5, IBM AIX 6.1, MS Windows Server 2008 R2, IBM AIX 7.1, MS Windows Server 2012, Windows 8, Windows RT, Windows 8 64-bit, Windows 8.1, Windows 8.1 64-bit, MS Windows Server 2012 R2, Windows RT 8.1, Sun Solaris 11, Windows 10, Novell Open Enterprise Server 2, Novell Open Enterprise Server 11
- 760 Watt
- Power Consumption Standby
- 80 Watt
- Power Consumption Sleep
- 3.2 Watt
- First Copy Out Time B/W
- 6.5 sec
- First Copy Out Time Colour
- 7.5 sec
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 5000 pages , 1 x toner cartridge (cyan) - up to 5000 pages , 1 x toner cartridge (magenta) - up to 5000 pages , 1 x toner cartridge (yellow) - up to 5000 pages
- FCC Class B certified, CSA, UL, VCCI Class B ITE, CISPR 22 Class B, DEMKO, GS, EN55024, IEC 60320-1, EN55022 Class B, CB, ICES-003 Class B, C-Tick Class B, MIC, EK, UL 60950-1, IEC 60950-1, EN 60950-1, CCC Class B, BSMI Class B, IEC 60825-1, FDA, CAN/CSA-C22.2 No. 60950-1
- ENERGY STAR Certified
- Limited warranty - 4 Years
- 76.3 cm
- 58.8 cm
- 55.9 cm
- 82.3 kg
- Shipping Width
- 105.3 cm
- Shipping Depth
- 76 cm
- Shipping Height
- 76 cm
- Shipping Weight
- 95.91 kg
- Sound Emission
- 55 dBA (operating)
- 10 °C
- 32 °C
- 15 - 80%
Lexmark Staples | In Stock | £115.53 |
Lexmark Cs/Cx827 Cyan Return Program Toner Cartridge 15K | In Stock | £255.90 |
Lexmark CS827de/CX827de Black Return Toner Catridge 20K | In Stock | £195.99 |
Lexmark Cs/Cx827 Magenta Return Program Toner Cartridge 15K | In Stock | £255.90 |
Lexmark Waste Toner Bottle 115K | In Stock | £32.44 |
