The Lexmark C925de color printer delivers outstanding A3 color printing, easy-to-use features and productivity solutions, all through an affordable, compact design.
The color touch screen allows you to operate your printer with ease and confidence through smart and intuitive navigation, easy access to workflow solutions and shortcuts, and the ability to preview your documents and print jobs at the device.
Intuitive Colour Touch Screen
The 10.9 cm (4.3 inch) colour touch screen allows you to operate your printer with ease and confidence through smart and intuitive navigation, easy access to workflow solutions and shortcuts, and the ability to preview your documents and print jobs at the device. -
Affordable A3 Colour Printing
Vibrant, professional-quality output on a wide variety of media for more colour printing in-house. Supports media up to 11.7 x 48 inches. -
Load Multiple Media types
150-sheet and 250-sheet input trays and a multipurpose feeder come standard, allowing you to load three media types. -
Robust connectivity makes it easy to integrate into most network environments. -
Lexmark Solutions
Reduce unnecessary printing and simplify work processes through solution applications preloaded on your device. Choose additional Lexmark solutions to fit your unique workflow needs. -
Advanced Security
Protect your device, data and network with innovative security controls, like authentication and authorisation, and an optional hard disk with disk wiping and encryption.
- Lexmark C925de - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 48.3 kg
- Media Size Class
- A3/Ledger
- Max Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
- Print Speed
- Up to 31 ppm - B/W - A4 (210 x 297 mm) , Up to 31 ppm - colour - A4 (210 x 297 mm) , Up to 26 spm - B/W duplex - A4 (210 x 297 mm) , Up to 30 ppm - colour - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 600 dpi
- Max Resolution (Colour)
- 600 dpi
- Image Enhancement Technology
- 1200 IQ
- Automatic Duplexing
- Interface
- USB, Gigabit LAN, USB host
- Processor
- 800 MHz
- RAM Installed (Max)
- 256 MB (1.25 GB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, XPS, PDF 1.6, xHTML
- Media Type
- Envelopes, transparencies, labels, plain paper, cards
- Total Media Capacity
- 450 sheets
- Media Handling
- 250-sheet input tray, 150-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 200000 pages
- Recommended Monthly Volume
- 2500 - 10000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- System Requirements
- Microsoft Windows 2000, IBM AIX 5.2, Apple MacOS X, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, HP-UX 11.11, Microsoft Windows Server 2003, Novell NetWare 5.1 SP6 or later, Novell NetWare 6.0 SP3 or later, HP-UX 11.23, openSUSE 11.0, Microsoft Windows 7, openSUSE 11.1, IBM AIX 5.3, SunSoft Solaris x86 10, Red Hat Enterprise Linux WS 4, Microsoft Windows Vista, SuSE Linux Enterprise Server 11, Ubuntu 9.04, SUSE Linux Enterprise Desktop 11, Debian GNU/Linux 5.0, SUSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Red Hat Enterprise Linux WS 5, Microsoft Windows Server 2008, IBM AIX 6.1, Microsoft Windows Server 2008 x64 Edition, HP-UX 11.31, Ubuntu 9.10, Linspire 6.0, Red Flag Linux Desktop 6.0, Ubuntu 10.04, Linux Linpus Desktop 9.6
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 62.2 cm x 55.7 cm x 42 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 600 dpi
- 600 dpi
- 1200 IQ
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 11 sec
- Fonts Included
- 39 x scalable PPDS , 5 x bitmapped PPDS , 158 x scalable PostScript , 84 x scalable PCL , 2 x bitmapped PCL
- Media Handling
- Processor
- 800 MHz
RAM
- 256 MB / 1.25 GB (max)
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), US No 9 (98.6 x 225.6 mm)
- 450 sheets
- Media Feeders
- 1 x automatic - 150 sheets , 1 x automatic - 250 sheets , 1 x automatic - 50 sheets
- Max Media Capacity
- 2100 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 200000 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP, AppleTalk, UDP/IP, NTP, ICMP/IP, LPR/LPD, ARP, FTP, BOOTP, DHCP, DNS, RARP, Bonjour, DDNS
- Remote Management Protocol
- Telnet, SNMP 3, SNMP 2c, HTTP, NDPS, NDS, HTTPS, TFTP, IPP 1.1
- SSL, Apple Bonjour, LEAP, TLS, IPsec, 802.1x
- Expansion Slots
- Memory
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- FCC Class A certified, TUV GS, CISPR 22 Class A, SABS, VCCI Class A ITE, EN55024, EN55022 Class A, IEC 60320-1, AS/NZS 60950-1, PSB, MIC, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07, TUV Rh, BSMI CNS 13438, A-Tick, FDA, UL-AR, GOST-R
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site - response time: next business day
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 39 dBA
- Sound Emission (Operating)
- 53 dBA
- 62.2 cm
- 55.7 cm
- 42 cm
- 48.3 kg
- Width (Shipping)
- 68 cm
- Depth (Shipping)
- 74.9 cm
- Height (Shipping)
- 87.6 cm
